01-08-2015 01:16 PM - edited 03-07-2019 10:08 PM
Hello guys,
I have an issue here with my 2960SI switch..
I decided to upgrade it with a newer IOS (previosuly it had some version of lanlite and worked fine)
I have tried the common 2960S IOS versions, but all of them were hanging after saying "image uncompressed and installed, executing..."
This time I tried to install a lanlite version of IOS, I already tried 2 of them, the 12.2(58) and 12.2(52)SE, both of them load, perform a POST, everything is successful and hang at the end, the last info that it shows is the following:
(The first image, 12.2(58) loaded at the very beginning, however, after I realoded the router to fix BAUD it never came back)
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960-24-S 12.2(52)SE C2960-LANLITEK9-M
%Warning! Hostname should contain at least one alphabet or '-' or '_' character
##X9†ÌÏÌ7°³viK2rµä6Â_H·g6C =0‹Íq«ü2°öp5y6˜þ
Here my console stops reacting..
What I am doing wrong?
Solved! Go to Solution.
01-09-2015 01:16 AM
I had a similar issue with a 3750x which hung after decompressing the image.
The fix for me was to delete all files from the flash (literally everything), boot into Rommon and Xmodem over a new IOS.
This then worked fine.
Mine was possibly a corruption in the flash but as it was a production switch, I didn't have the time to did deeper!
01-08-2015 05:39 PM
Post the entire bootup process please.
01-09-2015 05:41 AM
Leo, this is the entire boot process
switch: boot
Loading "flash:c2960-lanlitek9-mz.122-52.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c2960-lanlitek9-mz.122-52.SE.bin" uncompressed and installed, entry
point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 12.2(52)SE, RELE
ASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:49 by sasyamal
Image text-base: 0x00003000, data-base: 0x01300000
Initializing flashfs...
Using driver version 1 for media type 1
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 3870720
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 3869696
mifs[3]: mifs fsck took 0 seconds.
mifs[3]: Initialization complete.
mifs[4]: 4 files, 1 directories
mifs[4]: Total bytes : 27998208
mifs[4]: Bytes used : 7804416
mifs[4]: Bytes available : 20193792
mifs[4]: mifs fsck took 1 seconds.
mifs[4]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-24-S (PowerPC405) processor (revision J0) with 65536K bytes of me
mory.
Processor board ID FCQ1519Y48Z
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 58:35:D9:4B:96:80
Motherboard assembly number : 73-12613-05
Power supply part number : 341-0097-03
Motherboard serial number : FCQ1518077F
Power supply serial number : AZS151811A9
Model revision number : J0
Motherboard revision number : A0
Model number : WS-C2960-24-S
System serial number : FCQ1519Y48Z
Top Assembly Part Number : 800-32799-01
Top Assembly Revision Number : G0
Version ID : V06
CLEI Code Number : COMSJ00ARD
Hardware Board Revision Number : 0x0A
nþ^+¾s X9†ÌÏÌ7°³viK2rµä6Â_¦;H·g6C =0‹Íq«ü2°öp5y6˜þ
01-09-2015 01:16 AM
01-09-2015 05:41 AM
Thanks devils, I will try that!!
01-09-2015 06:45 AM
Devils,
I just formatted the flash card and did the fsck check, no errors..
Uploaded the same image and it worked!!!
Thanks a lot!! That was really a good experience for me!
01-09-2015 07:05 AM
Your welcome, my issue was slightly different but the symptoms were similar.
I just figured there was little to be lost by clearing the flash so it was worth a try!
Glad it worked
