Cisco Expressway softphone is not registering externally
Cisco Kbsl
Hi All
Recently we have deployed Expressway C and E  managed to get MRA to work completely fine
But after that we have to change the Expressway E IP address and now the IM&P service and directory is working fine but phone service is not registering. Traversal zone is active. Do you have any idea about this problem? I have completely stuck on this problem, I have tried everything I could to fix this. I even done a factory-reset to Expressway C and E and created traversal zone again. But still the problem is same. Pls let me know any solution to this or how to troubleshoot this
Here are some info
CUCM and CIMP ver 10
Expressway ver X8.5 (first I deployed X8.2 but after this issue I upgraded it to X8.5)
Expressway is in single nic mode
Jabber in internal network working completely fine. In External (public internet) IM&P service and directory is working but softphone is not registering it gives the below error on Jabber connection status
Softphone - Unhealthy
Status: Not connected
Protocol: SIP
Address: 10.3.146.201 (CCMCIP - Expressway)
Reason:Connection error. Ensure the server information in the Phone Services tab on the Options window is correct. Contact your system administrator for assistance.
Deskphone - None
Protocol: CTI
Address: 10.3.146.201 (CTI)
Presence - Healthy
Status: Connected
Address: ExpresswayEdge.mydomain.com
Protocol: XMPP
Port: 5222
Directory - Healthy
Status: Last connection successful.
Protocol: UDS (HTTPS)
I do not see the REGISTER message being received in the Expressway-E or Expressway-C logs. This suggests the following possibilities:
1) The Jabber client did not send it
2) The logs did not capture the time frame that the REGISTER was sent
3) The firewall is blocking tcp 5061.
I didn't see the Jabber Problem report which would tell us what is happening. Can you provide this after recreating the problem?
13 Replies 13
George Thomas
Level 10
Level 10
Have you tried doing a reset of Jabber from the client itself? Is port 5061 open to this new IP?
Please rate useful posts.
Yes I completely uninstalled the Jabber in windows and re-installed id but problem is same.
According to the our security expert he has given the same set of rules as old IP. Also in firewall monitoring window, it show no blocked traffic to Expressway Edge.
If some ports are blocked between between Expressway Edge and Core is it possible to show traversal-Zone in active state?
Yes, even if the ports from internet to Exp-E are closed, the traversal-zone will come up. Can you post Jabber and ExpC/E logs here?
Hi George,
Thanks for the information.
Here I am sending the logs. I also included the TCP dump in here
Pls download logs with below link
https://app.box.com/s/zymrasfj8mmhzjy52xal
Hi Paul,
Thanks for the reply. Here I am sending the Jabber logs and Expressway C / E logs. Pls use the below link
https://app.box.com/s/q6gl38s1p5m4ithmt21p
Can you kindly clarify your point. Is this REGISTER message sent by jabber client to Expressway Edge? Is it on sent to port 5061? So if this is blocked, it should be blocked by external firewall?
Hi All,
Think we have found some information on this. The messages to port 5061 is not blocked by the firewall but it is most probably blocked by our ISP.
Can we change the  Expressway E listening port 5061 to any other port? I have changed it from Expressway E "Configuration -> Protocols -> SIP" to 7061 but still it doesn't work. Is there any other task to complete this?
Hi All
Issue is resolved
Restart to Expressway E has done the trick :)
Thanks you very much Paul and George. Your guidance helped me to resolve the issue
I'm trying to set MRA with expressway C/E 8.2 but I have problems to set
certificates. what type of CA did you use?
I 've read the guides ( cisco expressway certificate)  but no clear for me.
I have no experience with certificates so I'd like to follow the less complex option
regards
Hi Filiberto,
I used the Microsoft CA for this.
If you use Microsoft CA first create "client server" certificate template and create Expressway certificates using this template. Procedure is in 21 page in below guide
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Cisco-Expressway-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
Hi Kbsl
I'm not good at English Please bear with me.
I have same problem too
Did you change sip listening port and restart expressway-E and then resolved this issue?
I've changed sip listening port on expressway -E and then restart Expressway-e but i still phone service is not registering. only working IM and directory service.
Do you have any idea ?
Yes, I've changed sip listening port on expressway -E and then restart Expressway-e. Have you restarted the Jabber client? What SIP port did you change? is it 5061?
If so try doing a telnet to SIP port on expressway -E from internet. This will confirm you have correctly changed the SIP port and on expressway -E and pot is not blocked by SP of Firewall (change of SIP port will need change if external firewall rules)
i had this issue too,
for me, that's because expressway can't control old 7900 series phones with sccp firmware, like: 7942, 7962..
and if i give a newest model like 7841, jabber will take control successfully..
..if this (helps) or (answered your question), please click (Helpful) or (Accept as Solution)..
