01-11-2015 01:40 PM - edited 03-07-2019 10:10 PM
Solved! Go to Solution.
01-12-2015 11:59 AM
Your 4500 is routing.
What you need for this to work is -
1) routes added to the Comcast router for the vlan 2/3/4 subnets. It's not a Cisco device but something like -
ip route 10.2.102.0 255.255.255.0 10.2.10.125 <-- this is the IP on the gi0/48 interface
ip route 10.2.103.0 255.255.255.0 10.2.10.125
etc.
2) you will also need NAT setup on the Comcast router for these subnets.
3) As a side issue currently your gi0/48 is using DHCP although in your diagram you have used the .125 IP address. If this could change on reboot then obviously your routes on the Comcast router would stop working so it would be better not to use DHCP and give it a static IP.
It can be the same one if you want.
Jon
01-12-2015 12:18 AM
I haven't specifically worked on a 4500 switch but looking at the config posted above, I see no obvious issues.
Once you plug a host into each of the ports, the SVI's should come up.
The command 'ip routing', usually does show in the running config but like anything Cisco, it may vary from model to model.
Can you run the following command and post the output.
#show ip interface brief | i Vlan
Can you also post the results of the following:
#show ip route
01-12-2015 11:50 AM
Thanks for the response. Here is the output:
CAM-Core#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.2.10.1 to network 0.0.0.0
10.0.0.0/24 is subnetted, 3 subnets
C 10.2.10.0 is directly connected, GigabitEthernet4/48
C 10.2.102.0 is directly connected, Vlan2
C 10.2.103.0 is directly connected, Vlan3
S* 0.0.0.0/0 [1/0] via 10.2.10.1
CAM-Core#show ip int brief | i Vlan
Vlan1 unassigned YES NVRAM down down
Vlan2 10.2.102.1 YES NVRAM up up
Vlan3 10.2.103.1 YES NVRAM up up
Vlan4 10.2.104.1 YES NVRAM up down
CAM-Core#
Vlan 4 is down because nothing is attached to it at the moment, so neglect that if need be. Vlan 2 can ping 3 and vice versa, however neither are able to reach the outside gateway (10.2.10.1)
01-12-2015 11:59 AM
etc.
Jon
01-12-2015 12:45 PM
Thanks for your help, Jon! I forgot that the switch was running through an Untangled Firewall prior to the Comcast gateway; nevertheless, the solution was the same.
