question about configuration cisco ap aironet 1100
Essam H
I have Cisco AP Aironet 1100 and I have 5 vlans in my network as the fallowing:
vlan101 with name (APmangm101)
vlan4 with name (Voice4)
vlan6 with name (User6)
vlan8 with name (inter8)
and vlan100 is native vlan
step1
I configured the SSID and Map it to respective VLANs (vlan4,vlan6,vla8)as the fallowing:
Dot11 ssid Voice4
vlan 4
authentication open
authentication key-managment wpa
wpa-psk ascii admin4444
mbssid guest-mode
exit
Dot11 ssid User6
vlan 6
authentication open
wpa-psk ascii admin666
mbssid guest-mode
exit
Dot11 ssid inter8
vlan8
authentication open
wpa-psk ascii admin888
mbssid guest-mode
exit
Step 2
Assigning the encryption to different SSIDs with repective Vlans.
int dot11Radio 0
mbssid
encryption vlan 4 mode ciphers aes-ccm
encryption vlan 6 mode ciphers aes-ccm
encryption vlan 8 mode ciphers aes-ccm
ssid Voice4
ssid User6
ssid inter8
Step 3
Configuring the sub interface for Dot11 radio 0 and Ethernet
interface Dot11Radio0.100
encapsulation dot1Q 100 native
bridge-group 100
exit
interface fastethernet0.100
bridge-group 100
exit
interface Dot11Radio0.101
encapsulation dot1Q 101
bridge-group 101
exit
interface fastethernet0.101
bridge-group 101
exit
interface Dot11Radio0.4
encapsulation dot1Q 4
bridge-group 4
exit
interface fastethernet0.4
bridge-group 4
exit
interface Dot11Radio0.6
encapsulation dot1Q 6
bridge-group 6
exit
interface fastethernet0.6
bridge-group 6
exit
interface Dot11Radio0.8
encapsulation dot1Q 8
bridge-group 8
exit
interface fastethernet0.8
bridge-group 8
exit
bridge irb
bridge 1 route ip
exit
Step 4
Configuration on the switch
int g1/0/3
switchport mode trunk
switchport trunk native vlan 100
switchport trunk allowed vlan 100,101,4,6,8
exit
My question:
1-The AP is work with Multi SSID and I can connect to any SSID and and do ping to any network, but when try to do ping to AP's IP management (172.16.101.20) I can't do it and can't access ass webpage to AP?
2-whene I type this command (At the bottom) the AP is disconnect and I can't ping to it even reload it:
 bridge-group 100
why it disconnect?
Note:
interface BVI1
 ip address 172.16.101.20 255.255.255.0
 ip default-gateway 172.16.101.254
Stephen Rodriguez
duplicate
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
duplicate
HTH,
Steve
What did you mean duplicate?
you have the same question posted three times in this sub-board. I provided a possible solution on another thread. Marking it duplicate helps everyone trying to assist to only answer in one thread instead of having answers spread across multiple.
Steve
HTH,
Steve
