IP Phone Visio template
crbates
Level 5
Level 5
I found the IP phones Visio template at:
http://www.cisco.com/c/en/us/products/visio-stencil-listing.html
This template is over 11 years old (5/12/04).  Is there an updated template with new phone is it?
PS:  If you go to the 7841 support page, the link there points back to this file.
Thanks.
5 Replies 5
adawa
Level 3
Level 3
Hello, crbates.
The link you provided is yet to be updated by Cisco and unfortunately, updates on Visio stencils on Cisco devices are limited at the moment on Cisco.com. What prompted you to look into this? Are you looking at implementing Cisco phones? It may help you get in touch with your Cisco partner for more reference. Kind regards.
I work for a partner and needed the new phone models for a drawing for a customer.
Understood. I do not have Visio to check this file out. However, have you tried downloading the Visio file on this link (The 945 KB zip file)?
http://www.cisco.com/c/en/us/support/collaboration-endpoints/unified-ip-phone-7841/model.html
Regards.
Yes, it points back to the old file and does not have a 7841 in it.
Rob Huffman
Hi there,
I might try posting this query up on this thread;
https://supportforums.cisco.com/discussion/11132746/how-request-missing-visio-stencils?page=3
Brett Newman "Cisco Visio Productionfrom Visimation the producer of the Visio stencils is quite active and answers a ton of these type of requests.
Cheers!
Rob
