01-12-2015 11:31 PM - edited 03-07-2019 10:12 PM
I have a quick question. We recently implemented VPC based network design with few SVIs (with HSRP) on a pair of NEX 5500s, but I forgot to include the 'peer-gateway' command. I understand the benefit of that command on FHRP like HSRP. My question is, if I apply that on a production NEX 5500 switches, would that cause any downtime? Could someone please confirm? Many thanks in advance!
Mark
Solved! Go to Solution.
01-13-2015 05:50 PM
Mark,
It usually does not cause disruption, however we always suggest do it after hours.
01-14-2015 05:43 AM
It shouldnt, but again we request you to kindly do it out of office hours or in MW.
below is the detail info on Auto-recovery:-
http://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/116187-configure-vpc-00.html#anc5
01-13-2015 05:01 PM
Hi there,
Any ideas? By the way, we have 5 HSRP groups currently servicing a number of servers. I assume there's no impact, just ensuring my hunch is right before I issue the command :-)
TIA,
Mark
01-13-2015 05:50 PM
Mark,
01-13-2015 07:22 PM
Thanks a lot guys. I assume it will be the same with 'peer-switch' command, no downtime if I issue them?
I am planning to issue both of them on our production switches in the near future.
01-13-2015 07:39 PM
Mark,
Thanks for the update. If you dont have any further query could you please mark this thread as answered rather than leaving it as unanswered/open questions.
Thanks in advance.
01-14-2015 01:09 AM
Sorry for another question, if I also include 'auto-recovery' and 'peer-switch' in our scheduled changes on the NEX switches, would that cause downtime?
01-14-2015 05:43 AM
01-14-2015 11:43 PM
Thanks again InayathUlla !
01-13-2015 06:21 PM
I don't think adding the 'peer-gateway' command will cause an outage but as Inayath also noted you should do it during a short maintenance window just in case.
01-13-2015 08:01 PM
There is no down time, I have done this with N7Ks in the past.
RE peer switch command I would do this out of hours for sure. I would say expect some down time even if there isn't any.
