01-13-2015 12:55 PM - edited 03-14-2019 02:18 PM
Hey all,
Wanted to know how to setup either a CVP script or ICM script to allow a customer to call in and shutdown their call center and then call back in to reopen it. I've seen posts for CRS but can't seem to find anything for UCCE 9.X through either CVP or ICM. Any help would be great.
Marcin
Solved! Go to Solution.
01-13-2015 01:04 PM
I'll give you the basics using CVP or really any IVR.
- Create admin script with a PIN to allow to get int. Then ask the caller to press 1 for close or 2 to open the call center. Based on input, write data to some back end system, preferably a database.
- When calls goes into queue, this application plays please hold and music at the very end it checks in the database field to see if the call center is still closed. At that point you play some message and pass a disconnect flag back to ICM to release the call.
david
01-13-2015 01:04 PM
david
01-13-2015 01:22 PM
Thanks David.
That sound about right for what i want to do. Would you happen to have any examples I could skim over?
Thanks.
