Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919165members
1223255discussions
Community Activity
UCCX IPCC Agent Line - Conference Call / Warm Transfer
We have our UCCX agents set up with 2 extensions:1 - Personal DN - no restrictions2 - Agent/ IPCC extension - set to 2 max calls 1 busyAgents receive calls from the queue to their IPCC extension as designed. However, they run into issues when they tr...
svk253 by Level 1
  • 45 Views
  • 1 replies
Not seeing debug dot1x or mab event log entries on IOS-XE machines.
Hello all,20+ years ago I used debug all the time, however not so much so in the last decade. Seems like last time I called TAC on the 3850 debug command they gave me some silly answer that debug was a Cisco TAC command.  WFIW All the Cisco.com debug...
wags by Level 1
  • 17 Views
  • 0 replies
Track Clients
In Prime Infrastructure, we were using the "Monitor / Monitoring Tools / Clients and Users" Track Clients feature for missing or lost devices.1.  Is there a way to export that list of MAC addresses to use in DNAC?2.  How do we add MAC addresses that ...
Mike Garb by Level 1
  • 25 Views
  • 0 replies
Cisco IP Phone não recebe ligações
Boa tarde, gostaria que os outros ramais aqui da empresa tambem recebecem ligações, porem somente o pabx recebe, se ligar no numero do ramal do colaborador não completa a ligação.
Migrating IPSec tunnel
Hello,I have a question about migrating a IPSec tunnel from between a Cisco C981F-k9 and a Cisco ASA firewall to a tunnel from the same Cisco C981F-k9 router to a Fortigate firewall. What is the 'best' way to migrate this tunnel?Currently I have conf...
MBestt by Level 1
  • 75 Views
  • 2 replies
Unable to upgrade Sandbox to full version
I have sandbox access but want to upgrade so I can test RCS capabilities (amongst other things).  When I click on "Request full access" it takes me to this: https://imimobile.com/products/imiconnect/sandbox/request-upgrade which gives me a cant reach...
jakehova by Level 1
  • 110 Views
  • 2 replies
CUIC - Total Talk Time
Hello all, Quick bit of background on this, the way our contact center currently works is that they have 1 line on their phones which they take both direct calls and calls via CSQ's. They have a few reports that they are using at the minute that incl...
Refreshing APIC-L2's with APIC-L4's
Hello all,I'm trying to make sure I understand the procedure for refreshing our current L2 APIC's with our new L4 APIC's.Currently our fabric is running 5.2(4) , and the new L4 APIC's require either 5.3 or 6.0.5 (which has just come out and is what w...
vv0bbLeS by Level 1
  • 60 Views
  • 2 replies
  • 1 Helpful votes
Cisco + Splunk: It's a new day for your data.
We’re excited to share that Splunk is now part of Cisco, enabling our customers to use their data in more powerful ways. Cisco + Splunk: Learn more. Just added: Executive Roundtable on the Future of Cisco and Splunk webinar on April 4th, 2024 | 10 AM...
US-ENG_IA-12_0_1200x628_BAN-S_JPEG_TOFU-no-B2P-SplunkWebinar-All_0_VISIT_6.JPEG.jpg CiscoSplunk-Community-600x300.jpg
Sabah Kadir by Community Manager
  • 2248 Views
  • 62 replies
  • 19 Helpful votes
Cisco ISE, Meraki MX FWs and dynamic VLANS
Hi,Our network only consists of Meraki products and now we are looking at the possibility of implementing 802.1X on wired and using Cisco ISE for that.Our business is geographically very spread out and we have both large and small branches. Some smal...
sdkhy by Level 1
  • 54 Views
  • 1 replies
SMTP route to Email Public address
Hello community,  i have a question, but can`t find answer on it.  If we have one listener for inbound and outbound communication and this private IP has NAT to public IP. We don`t have communication to mail server on private IP.  Is it a problem if ...
FTD is getting licensing connectivity issues
My FTD (FDM) running code 7.2.5.1-29 is getting the following message on the Smart License section: CONNECTION ISSUEFailed To Connect With License Server Lost connection for 0 days (Next Sync on 28 Mar 2024 11:06 PM). Please check and make sure the m...
Nexus 5k vPC pair connecting to VxRail nodes
First I'll state i also have an open case with Vmware.  I inherited a vPC pair that had a number of vPC set up, but the multiple links to the VxRail host nodes were trunk links.  We lost the secondary so only the trunks to the primary vPC were up.  A...
