01-14-2015 11:58 AM - edited 03-07-2019 10:13 PM
I have a stack of (4) 2960X FPS-L-48 switches which support SFP only that will uplink, via fiber, to another stack of (2) 2960X FPS-L-48 SFP only switches. A port channel will be created between the two stacks. I need to know what the throughput would be over the port channel between the stacks.
Thanks in advance.
Solved! Go to Solution.
01-14-2015 12:44 PM
The potential throughput will be the combined speed of the interfaces in the etherchannel.
Bear in mind though that for the same conversation between two end devices etherchannel uses the same physical link within the bundle so it's important to choose the right load balancing method.
See the configuration guide for details -
Jon
01-14-2015 03:13 PM
for a total of (8) ports in the etherchannel bundle?
Yes, this is the maximum number of ports you can have in an etherchannel.
Is that what you are asking ?
Jon
01-14-2015 12:44 PM
Jon
01-14-2015 02:59 PM
Hi Jon,
So does that mean that I can only have a total number of (4) ports on stack 1 and (4) ports on stack 2 for a total of (8) ports in the etherchannel bundle?
01-14-2015 03:13 PM
Jon
01-14-2015 03:28 PM
Yes, that's it. Thanks alot.
01-14-2015 03:56 PM
Racquel
Just to clarify.
You were asking about throughput so I concentrated on that.
But if you use LACP then you can have double the number of ports but half of them are in standby mode.
What this means is that they are not used to forward traffic but they can replace failed ports that were forwarding.
So the throughput is still the same but I just wanted to point that out in case it is an option for you.
Again, see the configuration guide for full details.
Hope I haven't confused the issue :-)
Jon
01-14-2015 03:56 PM
Jon,
No, eveyrthing is quite clear. I saw that LACP option as well. Thank you for being concise.
