01-17-2015 01:12 AM - edited 03-17-2019 01:37 AM
Dear All,
currently i try to register ata 187 on CME.
when i debug tftp event, i keep searching for the firmware:
*Jan 17 09:05:00.583: TFTP: Looking for CTLSEPE16D1508A901.tlv
*Jan 17 09:05:00.807: TFTP: Looking for ATAE16D1508A901.cnf.xml
*Jan 17 09:05:01.023: TFTP: Looking for XMLDefault.cnf.xml
*Jan 17 09:05:01.023: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 4, size 3451 for process 170
*Jan 17 09:05:01.035: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 170
i already have the firmware in my flash:
414 2118056 Jan 17 2015 15:54:56 +07:00 APPATA187.9-2-3-1.img.sgn
415 491 Jan 17 2015 15:55:16 +07:00 ATA187.9-2-3-1.loads
416 2818472 Jan 17 2015 15:55:36 +07:00 BFSATA187.9-2-3-1.img.sgn
417 624124 Jan 17 2015 15:56:12 +07:00 KNLATA187.9-2-3-1.bin.sgn
here is my configuration in CME:
voice register global
mode cme
source-address 172.16.49.2 port 5060
max-dn 30
max-pool 20
load ATA-187 ATA187.9-2-3-1
load 8831 sip8831.10-3-1-16.loads
authenticate register
timezone 41
time-format 24
tftp-path flash:
create profile sync 0030194817073399
tftp-server flash:APPATA187.9-2-3-1.img.sgn
tftp-server flash:ATA187.9-2-3-1.loads
tftp-server flash:BFSATA187.9-2-3-1.img.sgn
tftp-server flash:KNLATA187.9-2-3-1.bin.sgn
do i miss something?
need help.
Thx,
Anju
01-17-2015 04:52 AM
Looks like you havent defined the phone and DN:
voice register pool 1
id mac XX:XX:XX:XX
type ATA-187
number 1 dn 1
dtmf-relay sip-notify
codec g711ulaw
voice register dn 1
number XX
name Fax
label Fax
Once you make these changes do create config under voice register global.
See below link for detailed configuration to register a SIP device - Its for 9971 but ATA setup will be quite similar:
Terry
Please rate all helpful posts
Edit: Sorry for any errors typing it from mobile
03-03-2015 04:36 AM
Try alias option like below
tftp-server flash:/ATAF025727846D4.cnf.xml alias ATAF025727846D4.cnf.xml
tftp-server flash:/ATA25727846D401.cnf.xml alias ATA25727846D401.cnf.xml
Check this like as well.
I hope it is informative for you.
