searching a telepresence device
hasan yenilmez
Hi all ,
I'm looking for  a device that I can make point to point video conversation .And I  don't have a cucm in the enviroment.
Does Cisco have any  device can do this?
thanks in advance
Paul Stojanovski
Hasan,
I'm not sure if this will help you but the Cisco TAC has a loopback number you can dial into.
Below are the details:
IP Dialing: 64.102.241.236
H.323/SIP Dialing: loopback@rtp.ciscotac.net
-P
hi Paul,
I tried to use loopback@rtp.ciscotac.net for testing purproses but I receive "moved temporarily" on my Expressway-C,E. however I can dial other addresses, for example 0262463194@csiro.au.
is it under maintenance now?
Patrick Sparkman
Hello Hasan -
Are you looking for recommendations on video conference endpoints?  You can take a look at the following document, Endpoint Product Matrix, refer to "Signaling Protocol" to let you know if it's a CUCM or VCS compatible endpoint.
bsiapco
Hello, hasan yenilmez. Cisco Telepresence would be a great solution for point to point that you're looking. Can you tell me more about the features that you need to have so i can give you the exact recommendation. Please email me at (bsiapco@cisco.com) to assist you further..
