01-20-2015 06:02 AM - edited 03-17-2019 01:39 AM
Having the issue with DTMF relay in according the following scheme: PSTN > Voice GW (MGCP) with ISDN PRI > CUCM 8.x > CUCX 9.1
CUCX has IVR AutoAttendant with the ability (via 'Get Digit String' and 'Call Redirect' steps) of extension/dn dialing.
The issue is external (PSTN) calling party's DTMF input is in most cases doesn't get into CUCX app.
If the same app is addressed from internal phone all works like a charm and stable. So it is hardly can be UCCX side.
I've used 'debug voip ccapi inout' in the beginning of dialing extension process.
Sometimes after dialing I get the following event for voice gateway (this output is for '2' was pressed):
Jan 20 16:12:45.804 MSK: //4684/D70BB10A88FE/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x48BB1030, Destination Mask=0x1, Destination Call Id=4685,
Source Call Id=4684, Digit=2, DigitBeginFlags=0x1,
Rtp Timestamp=0x61388EB9, Rtp Expiration=0x0
Jan 20 16:12:45.840 MSK: //4684/D70BB10A88FE/CCAPI/cc_api_call_digit_end:
Source Call Id=4684, Digit=2, Duration=80,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
But most of times after pressing any digit I don't get such an event.
This makes me think about DTMF relay instability issue. Which is probably relevant of using narrowband g729 codec.
All prompts for IVR app are recorded using g729 coding.
Also it is strange that after call completion dtmf relay mode is changed to in-band. As for active call it was out-of-band.
#sh run | i dtmf|package
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
<!--- While call is active
#show call act vo id 1AEB | i mf|Rate
tx_DtmfRelay=out-of-band
TxComfortNoisePak=0
RxComfortNoisePak=0
CoderTypeRate=g729r8
#show call hist vo br id 1AEB
1AEB : 4703 -1961823676ms.4697 +-10 +28280 pid:0 Originate
dur 00:00:28 tx:1342/26802 rx:1355/27100 10 (normal call clearing (16))
IP <cucx-ip-addr>:29682 SRTP: off rtt:0ms pl:24260/20ms lost:1/1/0 delay:60/60/80ms g729r8 TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
1AEB : 4702 -1961823676ms.4698 +0 +28290 pid:0 Originate
dur 00:00:28 tx:1398/27922 rx:1355/37940 10 (normal call clearing (16))
Telephony 0/2/0:15 (4702) [0/2/0.1] tx:28010/28010/0ms g729r8 noise:-84dBm acom:45dBm
<!--- After call is dropped from the far-end
#show call hist vo id 1AEB | i mf|Rate
tx_DtmfRelay=inband-voice
Any help will be highly appreciated.
01-21-2015 02:18 AM
Guys,
Any suggestions? Or it'll be simplier go to g.711 codec.. =)
01-21-2015 09:00 AM
Stewie,
There are two things you can do..
1. add dtmf package to your mgcp config
mgcp package-capability dtmf-package
2. configure mgcp dtmf to use low bit rate codcec
mgcp dtmf-relay voip codec low-bit-rate mode out-of-band
3. Once you have done the above two, reset mgcp with no mgcp/mgcp
test again and send us
debug mgcp packets
01-22-2015 04:57 AM
Ayodeji,
Ok. Before any suggested changes config from CUCM and MGCP gw were the following:
+ CUCM (see the screenshot CUCM-MGCPGW-Config-PSCL).
The problem persists. Then
#conf t
Enter configuration commands, one per line. End with CNTL/Z.
(config)#mgcp package-capability ?
as-package Select the Announcement Server Package
atm-package Select the ATM Package
dtmf-package Select the DTMF Package
fm-package Select the FM Package
fxr-package Select the FXR Package
gm-package Select the Generic Media Package
hs-package Select the Handset Package
it-package Select the IT Package
line-package Select the Line Package
mdr-package Select the MDR Package
mf-package Select the MF Package
pre-package Select the PRE Package
res-package Select the RES Package
rtp-package Select the RTP Package
script-package Select the Script Package
srtp-package Select the SRTP Package
sst-package Select the SST Package
trunk-package Select the Trunk Package
(config)#mgcp package-capability dtmf-package ?
<cr>
(config)#
(config)#mgcp dtmf-relay voip codec low-bit-rate mode out-of-band
(config)#
(config)#no mgcp
WARNING: no mgcp: Teardown MGCP application may take a while to clean up resources
(config)#
Jan 22 15:43:27.638 MSK: %MGCP_APP-6-MGCP_SHUTDOWN_COMPLETE: MGCP Shutdown has completed
(config)#
(config)#mgcp
(config)#
(config)#end
#wr
Building configuration...
[OK]
Test - the problem persists (see debug output from file 'debug.txt').
Seems every test call attempt different digits of the same extension are relayed but always incomplete.
Call history shows all my attempts were using inband-voice.
#show call hist vo | i mf
01-22-2015 08:46 AM
Stewie,
Sorry for the late reply..
Having looked at the logs and description there are few pointers as to what is going on here..
1. We could be looking at a dsp issue/tone generation issue
2. IOS bug that is mgcp related
To look further lets ensure that the digit are been generated by the gateway please send the ff:
debug vpm signal
debug vtsp tone
debug mgcp packet
NB: Do you hear the tones on the phone when you dial them?
01-23-2015 01:46 AM
Ayodeji,
Yes, I hear the tones when I dial them.
It seems only 'debug mgcp packets' generates output (there is no output at all for vtsp & vpm only debug) and I've attached its corresponding data.
Actually for dialing 20055 extension we've got the following result:
1st attempt - only 20 were relayed
2nd attempt - only 05 were relayed
3rd attempt - only 205 were relayed
#debug vtsp tone
This CLI command is now 'debug voip vtsp tone'
#debug voip vtsp tone
voip vtsp tone debugging is on
#debug vpm signal
Voice Port Module signaling debugging is enabled
#debug mgcp packet
Media Gateway Control Protocol packets debugging for all endpoints is on
#sh deb
VTSP:
debug voip vtsp tone is ON (filter is OFF)
Voice Port Module signaling debugging is on
MGCP:
Media Gateway Control Protocol packets debugging is on
#sh ver | i IOS
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
#sh inv | i chassis
NAME: "2851 chassis", DESCR: "2851 chassis"
01-23-2015 02:20 AM
Hi Stewie,
Lets try this..
debug vtsp dsp.
I just want to ensure that the vtsp module is sending the digits to the gateway after it has received them. So we can narrow down where the issue is.
I don't just want to jump to any conclusions. I am leaning towards upgrading the ios on the gateway but lets see I we see anything on this debug first
01-23-2015 04:05 AM
Ayodeji,
Voice gateway always keeps silence for this debug either for successfull or unsuccessfull relays.
#debug vtsp dsp
This CLI command is now 'debug voip dsm dsp'
#debug voip dsm dsp
DSP Stream Manager dsp debugging is on
#sh deb
DSM:
debug voip dsm dsp is ON (filter is OFF)
01-23-2015 04:15 AM
Can you upgrade IOS
01-26-2015 03:46 AM
Ayodeji, Abdel,
Can you recommend which IOS version to prefer? Current release:
#sh ver | i IOS
#sh inv | i chassis
#sh ver | i bin
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T6.bin"
I've also made a check against Cisco Download Software section and found the following:
12.4 - 12.4.25g(MD) [c2800nm-advipservicesk9-mz.124-25g.bin]
12.4T - 12.4.24T8(ED) [c2800nm-advipservicesk9-mz.124-24.T8.bin]
ISR's DRAM/Flash config is 256/128 and abovementioned are good with this.
Also I've changed GW's parametr 'Type Of DTMF Relay' on CUCM from 'Out of Band' to 'Current GW Config' with GW reset.
Its config didn't changed after that and stays the same. Problem also persists.
01-26-2015 04:24 AM
Hi Stewie
My first choice would have been to go to the later 15.1 M release, but as the constrain in your DRAM/FLASH, I would believe 12.4T - 12.4.24T8(ED) [c2800nm-advipservicesk9-mz.124-24.T8.bin] could be tried first to see if the problem still persist .
MonieM
01-28-2015 03:23 AM
Abdel, Ayodeji,
Current time I'm running on 12.4.24T8(ED) [c2800nm-advipservicesk9-mz.124-24.T8.bin].
Unfortunately the problem still persist.
Can you, please, advice next steps in troubleshooting this issue.
01-30-2015 05:54 AM
Gentlemen,
Any ideas? Thank you.
01-30-2015 06:38 AM
Hi Stewie
I have reviewed the original traces one more time and I can see some of the digits get sent Out-of-band, but some might not be, in which it is a suspect in the firmware interpertation of the digits or DSPs. I see also the negotiation accepts the NSE in-band DTMF relay, could you inforce it int he configuration and negotiate only inband and see if this will make any difference.
You can choose NSE or NTE-GW.
mgcp dtmf-relay voip codec all mode nse
or
mgcp dtmf-relay voip codec all mode nte-gw
and collect same debugs please
02-03-2015 12:27 AM
