01-23-2015 11:38 AM - edited 03-14-2019 02:21 PM
Can anyone tell me if a NIC (Intel I217-LM) is compatible with the CAD in UCCX 9.0.2?
The CSD gets an error when trying to use the Voice Monitoring on two specific agents.
01-27-2015 09:15 AM
Have a look at these tips: https://supportforums.cisco.com/discussion/11418046/uccx-silent-monitoring-not-working-and-recorded-file-also-not-playing
Basically I have never found a NIC that doesn't work with this. I know there probably are some... best test is see if wireshark can see the traffic with a properly configured active phone.
Aaron
01-27-2015 09:54 AM
+2, I've never had a NIC not work, but I've had NICs where I had to make slight tweaks to the driver or used a new driver. Wireshark will get your to a resolution a lot faster than anything else.
david
