02-02-2015 04:04 AM - last edited on 03-25-2019 01:39 PM by ciscomoderator
A FEX like a 2232 can be added to UCS to provide additional ports for connecting C-series servers. Do you still only license the ports used on the Fabric Interconnects - ie, I add a 2232 using 2x10GE uplinks to each FI, I gain 32 10GE connections for servers, but only use two port licenses on the FI?
J
Solved! Go to Solution.
02-02-2015 07:13 AM
Correct ! just be aware of the following caveat
Maximum Configurable vNICs/vHBAs Based on Number of FEX Uplinks
Table 3: Cisco UCS 6200 Fabric Interconnect
02-02-2015 07:13 AM
