Cisco 871 and 881 routers PCI Compliant?
webpageforum1
do you know if the Cisco 871 and 881 routers are PCI complaint for 2015 and if not, are they able to be updated to be PCI Compliant?
thanks,
I am a Franchisee for a pizza chain and they are stating the routers will not be compliant with the new credit card PCI standards.
Reza Sharifi
Any router can be PCI complaint as long you follow the PCI guide to harden the router and apply the correct filters.For example; one of the PCI requirement is to disable telnet access to the router and only use SSH.  So, this can easily be accomplished if you have the right IOS with security installed.
