02-02-2015 02:54 PM - edited 03-17-2019 01:48 AM
I am wondering if it is possible to have an external caller call into a meetme number via a DID or via a Transfer? I have the meetme conferencing setup using Call Mangager 8.6 w/ 2901 as a hardware conference bridge, and it works with internal phone. But when I try to use a DID and translate the call into a meetme conference number it connects, I hear the beep, and then the call disconnects.
Any suggestions?
Dan.
Solved! Go to Solution.
02-02-2015 02:59 PM
Either option works, you probably want to debug the exact reason for the disconnect.
Make sure you're actually using the HW CFB with the right codecs enabled.
02-02-2015 02:59 PM
02-02-2015 03:01 PM
Adding to Jaime's point, just wondering what are the Codecs you have allowed for the Meet Me Conf?
02-03-2015 08:40 AM
This was the problem. The device group didn't have the media resource group set, which in turn was not using the hardware conference bridge.
02-02-2015 03:00 PM
Yes, it is possible to have External Callers be conferenced into the Meet Me Conf.
However the Meet Me Conference must be set up Prior to the external call.
