ASA 5510 upgrade
Hi i have ASA 5510 with software ver 8.2 need to upgrade to version completable with this model.
need Suggestion.
Marvin Rhoads
How much memory does your 5510 have ("show ver | i MB")?
Older ones need a memory upgrade to go to 8.3+. If you're not very conversant with the ASA, the upgrade to 8.3+ can be challenging as that is where some significant changes were made in NAT and access-list syntax.
Otherwise the last 8.2 release (8.2(5) from February 2013) is pretty stable and fine for most purposes.
Thanks Marvin for your suggestion,
You're welcome. Please rate if the reply helped.
