Prime Collaboration Deployment 10.6 Migrating CM8.x to an existing CUCM 10.5 cluster?
richb1971
Level 4
Level 4
Quick and easy one hopefully:
Can PCD assist with migrating CUCM 8.6 to an existing live CUCM 10.5 ? Suspect not but fingers crossed :)
Rich
Jaime Valencia
No, the migration process means a NEW (blank OVAs) 10.x cluster will be installed by PCD to then transfer the information.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
java
Good to know...
Where can I find PCD to download at cisco.com?
Thank you
Pascal
Only upgrade files are available under downloads at cisco.com, fresh install ISO only comes with the 10.x media kit you need to order via PUT
java
OK...Thanks
Cheers,
Pascal
Cheers Jaime
