02-03-2015 05:30 AM - edited 03-17-2019 01:49 AM
Does anyone know what the intended use of the following baked in partitions are:
Global Learned E164 Numbers
Global Learned E164 Patterns
Global Learned Enterprise Numbers
Global Learned Enterprise Pattern
These are created during the installation of UCM 10.5 and I would like to understand how they can best be used.
Solved! Go to Solution.
02-03-2015 05:40 AM
Hi.
Those partitions are automatically created by CUCM to put learned pattern through ILS.
Here is a reference doc
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_011101.html#CUCM_RF_L56BD6F6_00
Carlo
02-03-2015 05:40 AM
Hi.
Carlo
02-03-2015 05:49 AM
Perfect! That was exactly what I was looking for. Thank you.
