02-03-2015 01:23 PM
We are in the process of troubleshooting disk mirroring on our RSP440-TR's. Every time we enable, the RSP crashes.
Detailed information on the three (3) scenarios and log results are listed below.
I'm curious if disk mirroring is necessary on our ASR9k's. I've read various posts that reference that there's no purpose to disk mirroring at all along with the following bug CSCus34978 where it references the RSP going corrupt after enabling disk mirroring.
https://tools.cisco.com/bugsearch/bug/CSCus34978
Any input from Xander & team would be much appreciated
Thanks!
-ae
Scenario 1
XR 4.3.4
1) install and activate all packages and SMUs
2) mirror location 0/RSP0/CPU0 disk0:disk1:
**Result - RSP CRASH
Scenario 2
XR 4.3.4
1) install only the mini PIE with TurboBoot
2) format disk1:
3) mirror location 0/RSP0/CPU0 disk0:disk1:
Scenario 3
XR 5.2.2
Scenario 1 - LOG
RP/0/RSP0/CPU0:LAB-01(config)#mirror location 0/RSP0/CPU0 disk0:disk1:
RP/0/RSP0/CPU0:LAB-01(config)#commit
Mon Feb 2 09:47:19.850 UTC
RP/0/RSP0/CPU0:Feb 2 09:47:20.023 UTC: config[65742]: %MGBL-CONFIG-3-FILESAVE_ERROR : The OS returned an error while SysDb was attempting to perform a file save operation. Any changes have been rolled back. Error: ''sysdb' detected the 'warning' condition 'The OS returned an error while attempting to access a file': No such file or directory'
% Failed to commit .. As an error (Unknown) encountered during commit operation. Changes may not have been committed:
RP/0/RSP0/CPU0:LAB-01(config)#RP/0/RSP0/CPU0:Feb 2 09:47:21.005 UTC: dumper[60]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
RP/0/RSP0/CPU0:Feb 2 09:47:21.005 UTC: dumper[60]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x108 at PC 0x420883b. Signal code 1 - SEGV_MAPPER. Address not mapped.
RP/0/RSP0/CPU0:Feb 2 09:47:21.005 UTC: dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 36886 (pkg/bin/redfs_svr)
RP/0/RSP0/CPU0:Feb 2 09:47:21.006 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 0(harddisk:/dumper) in use
RP/0/RSP0/CPU0:Feb 2 09:47:21.006 UTC: dumper[60]: %OS-DUMPER-6-DEFAULT_PATH_TMP : Setting default path to /tmp/dumper for core size less than 20971520. Core dump size 2613248, free memory size 10122571776.: default path for core dump
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EDI ESI EBP(fp) EXX
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R0 00000000 10023c34 041ff200 fdfd5cd0
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EBX EDX ECX EAX
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R4 00000000 0802417a 041ff150 042238b0
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : EIP(pc) CS EFL ESP
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R8 0420883b 000000f3 00011202 041ff1f4
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : SS
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-REGISTERS_INFO : R12 000000fb
RP/0/RSP0/CPU0:Feb 2 09:47:21.007 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #0 0x420883b
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #1 0x420cee8
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #2 0x420fa42
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #3 0x82476ae
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #4 0x8247656
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #5 0x8244737
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #6 0x421000d
RP/0/RSP0/CPU0:Feb 2 09:47:21.008 UTC: dumper[60]: %OS-DUMPER-6-TRACE_BACK : #7 0x4200290
RP/0/RSP0/CPU0:Feb 2 09:47:21.011 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: tmp(/tmp/dumper) in use
RP/0/RSP0/CPU0:Feb 2 09:47:21.012 UTC: dumper[60]: %OS-DUMPER-5-CORE_FILE_NAME : Core for process pkg/bin/redfs_svr at /tmp/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z on local_node
RP/0/RSP0/CPU0:Feb 2 09:47:21.110 UTC: redfs_config[388]: %MEDIA-REDFSAPI-4-MSG_SEND_FAILED : Unable to send message to redfs server, op 9, errno=3:No such process. : pkg/bin/redfs_config : (PID=241860) : -Traceback= b6d1780 b6d094a 42000a1 8eba427 8ebc701 82465d7 8244724 4200700 4200038
RP/0/RSP0/CPU0:Feb 2 09:47:21.134 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : /tmp/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z has just been written. size:1132202 md5:d089e0c7bfea5c744ae2e4c63ed960c4
RP/0/RSP0/CPU0:Feb 2 09:47:21.153 UTC: dumper[60]: %OS-DUMPER-5-DUMP_SUCCESS : Core dump success
RP/0/RSP0/CPU0:Feb 2 09:47:21.174 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : /tmp/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z before transfer. size:1132202 md5:d089e0c7bfea5c744ae2e4c63ed960c4
RP/0/RSP0/CPU0:Feb 2 09:47:21.174 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 4(dumper_harddisk:/dumper) in use
RP/0/RSP0/CPU0:Feb 2 09:47:23.422 UTC: dumper[60]: %OS-DUMPER-5-CORE_TRANSFER_STATUS : Transfer of Core file from /tmp/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z to harddisk:/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z on local_node suceeded.
RP/0/RSP0/CPU0:Feb 2 09:47:23.434 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : harddisk:/dumper/first.redfs_svr_88.20150202-094721.node0_RSP0_CPU0.x86.Z after transfer. size:1132202 md5:d089e0c7bfea5c744ae2e4c63ed960c4
Scenario 2 - LOG
Tue Feb 3 10:17:33.043 UTC
RP/0/RSP0/CPU0:Feb 3 10:17:33.116 UTC: config[65762]: %MGBL-CONFIG-3-FILESAVE_ERROR : The OS returned an error while SysDb was attempting to perform a file save operation. Any changes have been rolled back. Error: ''sysdb' detected the 'warning' condition 'The OS returned an error while attempting to access a file': No such file or directory'
RP/0/RSP0/CPU0:LAB-01(config)#File name: first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86
RP/0/RSP0/CPU0:Feb 3 10:17:34.103 UTC: dumper[60]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
RP/0/RSP0/CPU0:Feb 3 10:17:34.103 UTC: dumper[60]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x108 at PC 0x42086b9. Signal code 1 - SEGV_MAPPER. Address not mapped.
RP/0/RSP0/CPU0:Feb 3 10:17:34.103 UTC: dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 36885 (pkg/bin/redfs_svr)
RP/0/RSP0/CPU0:Feb 3 10:17:34.104 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 0(harddisk:/dumper) in use
RP/0/RSP0/CPU0:Feb 3 10:17:34.104 UTC: dumper[60]: %OS-DUMPER-6-DEFAULT_PATH_TMP : Setting default path to /tmp/dumper for core size less than 20971520. Core dump size 3104768, free memory size 11032899584.
RP/0/RSP0/CPU0:Feb 3 10:17:34.108 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: tmp(/tmp/dumper) in use
RP/0/RSP0/CPU0:Feb 3 10:17:34.109 UTC: dumper[60]: %OS-DUMPER-5-CORE_FILE_NAME : Core for process pkg/bin/redfs_svr at /tmp/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z on local_node
RP/0/RSP0/CPU0:Feb 3 10:17:34.213 UTC: sysmgr[94]: redfs_svr(1) (jid 88) (pid 36885) (fail_count 1) abnormally terminated, restart scheduled
RP/0/RSP0/CPU0:Feb 3 10:17:34.214 UTC: redfs_config[381]: %MEDIA-REDFSAPI-4-MSG_SEND_FAILED : Unable to send message to redfs server, op 9, errno=3:No such process. : pkg/bin/redfs_config : (PID=266423) : -Traceback= af9b7a4 af9a96e 42000a1 8e7144b 8e73274 822605f 82242b2 4200700 4200038
RP/0/RSP0/CPU0:Feb 3 10:17:34.251 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : /tmp/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z has just been written. size:1194760 md5:442035043a30db3efc69392affcdca80
RP/0/RSP0/CPU0:Feb 3 10:17:34.272 UTC: dumper[60]: %OS-DUMPER-5-DUMP_SUCCESS : Core dump success
RP/0/RSP0/CPU0:Feb 3 10:17:34.294 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : /tmp/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z before transfer. size:1194760 md5:442035043a30db3efc69392affcdca80
RP/0/RSP0/CPU0:Feb 3 10:17:34.295 UTC: dumper[60]: %OS-DUMPER-6-FALLBACK_CHOICE : Fall back choice: 4(dumper_harddisk:/dumper) in use
RP/0/RSP0/CPU0:Feb 3 10:17:36.913 UTC: dumper[60]: %OS-DUMPER-5-CORE_TRANSFER_STATUS : Transfer of Core file from /tmp/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z to harddisk:/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z on local_node suceeded.
RP/0/RSP0/CPU0:Feb 3 10:17:36.926 UTC: dumper[60]: %OS-DUMPER-6-CORE_MD5 : harddisk:/dumper/first.redfs_svr_88.20150203-101734.node0_RSP0_CPU0.x86.Z after transfer. size:1194760 md5:442035043a30db3efc69392affcdca80
Scenario 3 - LOG
RP/0/RSP0/CPU0:LAB-01#format disk1:
Tue Feb 3 11:35:48.676 UTC
Format will destroy all data on "disk1:". Continue? [confirm]
Device partition disk1: is now formated and is available for use.
Tue Feb 3 11:43:00.541 UTC
RP/0/RSP0/CPU0:Feb 3 11:43:00.724 : config[65755]: %MGBL-CONFIG-3-FILESAVE_ERROR : The OS returned an error while SysDb was attempting to perform a file save operation. Any changes have been rolled back. Error: ''sysdb' detected the 'warning' condition 'The OS returned an error while attempting to access a file': No such file or directory'
RP/0/RSP0/CPU0:LAB-01(config)#File name: first.redfs_svr_88.20150203-114301.node0_RSP0_CPU0.x86
RP/0/RSP0/CPU0:Feb 3 11:43:01.613 : dumper[60]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
RP/0/RSP0/CPU0:Feb 3 11:43:01.613 : dumper[60]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x108 at PC 0x42086b9. Signal code 1 - SEGV_MAPPER. Address not mapped.
RP/0/RSP0/CPU0:Feb 3 11:43:01.613 : dumper[60]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 36885 (pkg/bin/redfs_svr)
RP/0/RSP0/CPU0:Feb 3 11:43:01.725 : sysmgr[94]: redfs_svr(1) (jid 88) (pid 36885) (fail_count 1) abnormally terminated, restart scheduled
RP/0/RSP0/CPU0:Feb 3 11:43:01.726 : redfs_config[361]: %MEDIA-REDFSAPI-4-MSG_SEND_FAILED : Unable to send message to redfs server, op 9, errno=3:No such process. : pkg/bin/redfs_config : (PID=270514) : -Traceback= af367a4 af3596e 42000a1 8ebf44b 8ec1274 822605f 82242b2 4200700 4200038
02-03-2015 10:09 PM
Hi Andy,
It does not matter which SW version you use, the root cause for this problem is that there is a batch of new RSP shipments that come with 5.2.2 pre installed and have set a wrong ROMMON variable that causes the file system corruption. You need to go into ROMMON, issue "unset MIRROR_DISABLE" and "sync", then you can reset the system and your are good.
Florian
02-04-2015 05:39 AM
What are the commands in ROMMON to check to see what the current settings are? Thanks.
-ben
02-04-2015 05:41 AM
"set" gives you the list of current variables.
Florian
02-04-2015 09:59 AM
Thanks, Florian. I was able to disable that command in ROMMON.
rommon 1 > set
PS1=rommon ! >
?=0
MIRROR_DISABLE=Y
CLUSTER_RACK_ID=0
ACTIVE_FCD=1
IOX_ADMIN_CONFIG_FILE=
RMEMVA=
BSI=0
BOOT=disk0:asr9k-os-mbi-4.3.4.CSCui94441-1.0.0/0x100305/mbiasr9k-rsp3.vm,1;
CLUSTER_NO_BOOT=
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
rommon 2 > unset MIRROR_DISABLE
rommon 3 > sync
rommon 4 > set
PS1=rommon ! >
?=0
CLUSTER_RACK_ID=0
ACTIVE_FCD=1
RMEMVA=
BSI=0
CLUSTER_NO_BOOT=
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
rommon 5 > reset
EDIT 3 - I got mirroring to work on both the active and standby RSP (I had previously mistyped my command for mirroring and forgot to enable mirroring for 0/RSP1/CPU0)
RP/0/RSP0/CPU0:ios#format disk1:
Wed Feb 4 09:00:09.945 UTC
RP/0/RSP0/CPU0:ios#config
Wed Feb 4 09:00:17.471 UTC
RP/0/RSP0/CPU0:ios(config)#mirror location 0/RSP0/CPU0 disk0: disk1:
RP/0/RSP0/CPU0:ios(config)#mirror location 0/RSP1/CPU0 disk0: disk1:
RP/0/RSP0/CPU0:ios(config)#commit
RP/0/RSP0/CPU0:ios#sh mirror
Wed Feb 4 09:14:41.377 UTC
Mirror Information for 0/RSP0/CPU0.
Mirroring Enabled
Configured Primary: disk0:
Configured Secondary: disk1:
Current Mirroring State: Redundant
Current Physical Primary: disk0:
Current Physical Secondary: disk1:
Mirroring Logical Device: disk0:
Mirroring Logical Device2: disk1:
Physical Device State Flags
disk0: Available Enabled
disk1: Available Enabled
compactflash: Not Present
(null) Available
disk0a: Available
disk1a: Available
compactflasha: Not Present
harddisk: Available
Mirroring Rommon Variable
BOOT_DEV_SEQ_CONF = disk0:;disk1:
BOOT_DEV_SEQ_OPER = disk0:;disk1:
MIRROR_ENABLE = Y
RP/0/RSP0/CPU0:ios#redundancy switchover
Wed Feb 4 09:17:37.116 UTC
Proceed with switchover 0/RSP0/CPU0 -> 0/RSP1/CPU0? [confirm]
Initiating switch-over.
RP/0/RSP1/CPU0:ios#sh mirror
Wed Feb 4 09:57:23.658 UTC
Mirror Information for 0/RSP1/CPU0.
Mirroring Enabled
(null) Available
disk0a: Available
disk1a: Available
harddisk: Available
MIRROR_ENABLE = Y
02-04-2015 12:59 PM
Glad it worked out :)
02-13-2015 02:42 AM
I just got this procedure from TAC1. I assume router is running 5.1.3 with mirroring disabled
2. Check if this variable is set on both RSPs and clear them:
! on active RSP
run attach 0/RSP1/CPU0 ! or 0/RSP0/CPU0
nvram_rommonvar MIRROR_DISABLE
! it may list "y" here, meaning it is set
! if variable is set, then clear it:
run nvram_rommonvar MIRROR_DISABLE ""
! on standby RSP
run attach 0/RSP1/CPU0 ! or 0/RSP0/CPU0, depending on which RSP is a standby
3. Reload the router:
admin reload location all
But I cant test it for the next few days.
Marco
05-18-2015 11:31 AM
Marco - I tried your commands on a set of RSP440 we just received and I'm not really sure it did anything:
I'm assuming this means the variable is not set in rommon, correct?
05-25-2015 05:16 AM
Hi Beniamin.
It seem so.
Actually I got just 2s out 8s 440s with the variable set.
MM
02-03-2015 10:18 PM
Regarding the disk mirroring in general, as of today you can only install the OS on disk0 or disk1, there is no way to install it on the harddisk. So your whole OS runs on a single flash disk. As you probably know, there is a difference between IOS and IOS-XR, as the latter does regularly accesses the flash disk, its a complex OS that is not loaded into memory at once like in IOS. So corrupting the flash disk is like corruption your C: drive in Windows, its not a good idea. As you have multi Gigabit on your harddisk, there is literally no use for disk1, so using it for disk mirroring is still better than doing nothing with it, though if the OS does not correctly recognize that disk0 is faulty, yes then there is a chance that also disk mirroring does not safe you from problems, which are according to my experience interestingly not so much related to the box stopping traffic forwarding but more that you are not able to login any more via SSH or console because those processes that let you access the box, yup they need to read from the flash disk first ;)
Florian
02-04-2015 09:18 AM
Excellent point, Florian.
One more question for you - can you explain the relationship between disk0: on RSP0 and disk0: on RSP1? I expected that it was a 1:1 symmetry (that the files are the same on both disk0: on RSP0 and RSP1). However, when a do a dir disk0: when RSP0 is active and a dir disk0: when RSP1 is active, I am showing differences in the files present.
02-04-2015 10:03 AM
The dir command does not output the files in the same order, and there will be a few subtle differences but for the most part the packages, configuration, etc will be synced between the RSPs install media (disk0) automatically.
Sam
02-04-2015 10:24 AM
Sam - this does not appear to be the case. To test my hypothesis, I copied my 5.2.2 PIE and SMU files to disk0: while RSP0 was active. I ran a dir disk0: and saved the output. I then forced failover to RSP1 and ran a dir disk0: there. The files I just loaded on RSP0 disk0 are not present. For giggles, I tried to do an admin install add disk0:/xxx sync and it failed indicating the file not present.
I'm working with TAC now. SR 633501133
RP/0/RSP0/CPU0:ios#dir disk0:
Wed Feb 4 10:21:22.204 UTC
Directory of disk0:
46194 -r-- 2954492 Tue Feb 3 11:05:15 2015 .bitmap
17 -r-- 958464 Tue Feb 3 11:05:15 2015 .inodes
18 -rw- 0 Tue Feb 3 11:05:15 2015 .boot
19 -rw- 0 Tue Feb 3 11:05:15 2015 .altboot
46199 drwx 4096 Tue Feb 3 11:05:16 2015 LOST.DIR
46200 -r-- 40960 Tue Feb 3 11:05:15 2015 .longfilenames
46201 drwx 4096 Wed Feb 4 10:16:09 2015 config
46202 drwx 4096 Wed Feb 4 10:16:28 2015 eem_rdsfs
46258 drwx 4096 Tue Feb 3 11:06:35 2015 asr9k-scfclient-4.3.4
46204 drwx 4096 Wed Feb 4 10:20:15 2015 instdb
46265 drwx 4096 Tue Feb 3 11:06:36 2015 asr9k-diags-supp-4.3.4
46283 drwx 4096 Tue Feb 3 11:06:36 2015 asr9k-ce-4.3.4
46326 drwx 4096 Tue Feb 3 11:07:05 2015 asr9k-fwding-4.3.4
632673 drwx 4096 Tue Feb 3 11:07:25 2015 asr9k-base-4.3.4
985400 drwx 4096 Tue Feb 3 11:07:26 2015 asr9k-os-mbi-4.3.4
985411 drwx 4096 Tue Feb 3 11:07:35 2015 asr9k-cpp-4.3.4
2154951 drwx 4096 Tue Feb 3 11:07:39 2015 iosxr-ce-4.3.4
2230313 drwx 4096 Tue Feb 3 11:07:40 2015 iosxr-diags-4.3.4
2230354 drwx 4096 Tue Feb 3 11:07:53 2015 iosxr-routing-4.3.4
2517757 drwx 4096 Tue Feb 3 11:08:38 2015 iosxr-fwding-4.3.4
3664256 drwx 4096 Tue Feb 3 11:09:28 2015 iosxr-infra-4.3.4
5019864 drwx 4096 Tue Feb 3 11:09:29 2015 asr9k-mini-px-4.3.4
46217 drwx 4096 Wed Feb 4 10:16:20 2015 snmp
46218 drwx 4096 Wed Feb 4 10:16:28 2015 cepki
46219 drwx 4096 Wed Feb 4 10:15:58 2015 aaa
46220 drwx 4096 Wed Feb 4 10:16:19 2015 license
46221 -rw- 0 Wed Feb 4 10:00:16 2015 tar_report.txt
46222 drwx 4096 Tue Feb 3 11:15:46 2015 np
46223 -rw- 0 Tue Feb 3 11:22:07 2015 umass.log
5181266 -rw- 33870331 Tue Feb 3 12:22:39 2015 asr9k-asr901-nV-px.pie-4.3.4
5181267 -rw- 233950002 Tue Feb 3 12:23:03 2015 asr9k-asr903-nV-px.pie-4.3.4
5181268 -rw- 9461539 Tue Feb 3 12:23:37 2015 asr9k-asr9000v-nV-px.pie-4.3.4
5181269 -rw- 8370703 Tue Feb 3 12:23:39 2015 asr9k-bng-px.pie-4.3.4
5181270 -rw- 4714778 Tue Feb 3 12:23:41 2015 asr9k-doc-px.pie-4.3.4
5181271 -rw- 131029510 Tue Feb 3 12:23:55 2015 asr9k-fpd-px.pie-4.3.4
5181272 -rw- 7384279 Tue Feb 3 12:23:57 2015 asr9k-k9sec-px.pie-4.3.4
5181273 -rw- 722135 Tue Feb 3 12:23:58 2015 asr9k-li-px.pie-4.3.4
5181274 -rw- 15595126 Tue Feb 3 12:24:01 2015 asr9k-mcast-px.pie-4.3.4
5181275 -rw- 12343153 Tue Feb 3 12:24:03 2015 asr9k-mgbl-px.pie-4.3.4
5181276 -rw- 270639197 Tue Feb 3 12:24:27 2015 asr9k-mini-px.pie-4.3.4
5181277 -rw- 10678137 Tue Feb 3 12:24:30 2015 asr9k-mpls-px.pie-4.3.4
5181278 -rw- 10563 Tue Feb 3 12:24:31 2015 asr9k-optic-px.pie-4.3.4
5181279 -rw- 3050896 Tue Feb 3 12:24:33 2015 asr9k-services-px.pie-4.3.4
5181280 -rw- 1289610 Tue Feb 3 12:24:34 2015 asr9k-video-px.pie-4.3.4
5181281 -rw- 589717 Tue Feb 3 12:32:24 2015 asr9k-px-4.3.4.CSCum43188.pie
5181282 -rw- 359892 Tue Feb 3 12:32:25 2015 asr9k-px-4.3.4.CSCum46796.pie
5181283 -rw- 1006006 Tue Feb 3 12:32:26 2015 asr9k-px-4.3.4.CSCul93777.pie
5181284 -rw- 57235418 Tue Feb 3 12:32:32 2015 asr9k-px-4.3.4.CSCui94441.pie
5181285 -rw- 3509177 Tue Feb 3 12:32:33 2015 asr9k-px-4.3.4.CSCum03261.pie
17923599 -rw- 126 Wed Feb 4 10:16:38 2015 sam_crldb
5181287 drwx 4096 Tue Feb 3 14:43:39 2015 iosxr-security-4.3.4
5181478 drwx 4096 Tue Feb 3 14:43:39 2015 asr9k-k9sec-supp-4.3.4
5181481 drwx 4096 Tue Feb 3 14:43:39 2015 asr9k-k9sec-px-4.3.4
5181490 drwx 4096 Tue Feb 3 14:44:08 2015 asr9k-fpd-4.3.4
17923597 drwx 4096 Tue Feb 3 14:44:08 2015 asr9k-fpd-px-4.3.4
17923602 drwx 4096 Tue Feb 3 14:44:32 2015 asr9k-asr901-supp-4.3.4
17923608 drwx 4096 Tue Feb 3 14:44:32 2015 asr9k-asr901-nV-px-4.3.4
17923614 drwx 4096 Tue Feb 3 14:44:46 2015 asr9k-9000v-nV-supp-4.3.4
17923620 drwx 4096 Tue Feb 3 14:44:46 2015 asr9k-9000v-nV-px-4.3.4
17923626 drwx 4096 Tue Feb 3 14:44:58 2015 asr9K-doc-supp-4.3.4
21588833 drwx 4096 Tue Feb 3 14:44:58 2015 asr9k-doc-px-4.3.4
21588839 drwx 4096 Tue Feb 3 14:45:10 2015 iosxr-li-4.3.4
21588871 drwx 4096 Tue Feb 3 14:45:10 2015 asr9k-li-4.3.4
21588881 drwx 4096 Tue Feb 3 14:45:10 2015 asr9k-li-px-4.3.4
21588887 drwx 4096 Tue Feb 3 14:45:25 2015 iosxr-mcast-4.3.4
21846741 drwx 4096 Tue Feb 3 14:45:26 2015 asr9k-mcast-supp-4.3.4
21846781 drwx 4096 Tue Feb 3 14:45:26 2015 asr9k-mcast-px-4.3.4
21846789 drwx 4096 Tue Feb 3 14:45:41 2015 iosxr-mgbl-4.3.4
21969697 drwx 4096 Tue Feb 3 14:45:42 2015 asr9k-mgbl-supp-4.3.4
21969712 drwx 4096 Tue Feb 3 14:45:43 2015 asr9k-mgbl-px-4.3.4
21969719 drwx 4096 Tue Feb 3 14:45:58 2015 iosxr-mpls-4.3.4
22244526 drwx 4096 Tue Feb 3 14:45:58 2015 asr9k-mpls-px-4.3.4
22244531 drwx 4096 Tue Feb 3 14:46:11 2015 iosxr-service-4.3.4
22331693 drwx 4096 Tue Feb 3 14:46:12 2015 asr9k-service-supp-4.3.4
22376021 drwx 4096 Tue Feb 3 14:46:12 2015 asr9k-services-px-4.3.4
22376029 drwx 4096 Tue Feb 3 14:46:27 2015 iosxr-adv-video-4.3.4
22376152 drwx 4096 Tue Feb 3 14:46:27 2015 asr9k-adv-video-supp-4.3.4
22376178 drwx 4096 Tue Feb 3 14:46:28 2015 asr9k-video-px-4.3.4
5181313 drwx 4096 Tue Feb 3 14:59:23 2015 iosxr-adv-video-4.3.4.CSCum46796-1.0.0
22376227 drwx 4096 Tue Feb 3 14:59:23 2015 asr9k-px-4.3.4.CSCum46796-1.0.0
22376187 drwx 4096 Tue Feb 3 15:00:51 2015 iosxr-fwding-4.3.4.CSCum43188-1.0.0
22429544 drwx 4096 Tue Feb 3 15:00:51 2015 asr9k-px-4.3.4.CSCum43188-1.0.0
22376234 drwx 4096 Tue Feb 3 15:04:25 2015 asr9k-os-mbi-4.3.4.CSCui94441-1.0.0
22429558 drwx 4096 Tue Feb 3 15:04:27 2015 asr9k-base-4.3.4.CSCui94441-1.0.0
22429701 drwx 4096 Tue Feb 3 15:04:28 2015 asr9k-px-4.3.4.CSCui94441-1.0.0
23440873 drwx 4096 Tue Feb 3 15:31:04 2015 asr9k-cpp-4.3.4.CSCum03261-1.0.0
23440902 drwx 4096 Tue Feb 3 15:31:05 2015 asr9k-fwding-4.3.4.CSCum03261-1.0.0
23440925 drwx 4096 Tue Feb 3 15:31:05 2015 asr9k-px-4.3.4.CSCum03261-1.0.0
23440935 drwx 4096 Tue Feb 3 16:25:58 2015 asr9k-fwding-4.3.4.CSCul93777-1.0.0
23440942 drwx 4096 Tue Feb 3 16:25:58 2015 asr9k-px-4.3.4.CSCul93777-1.0.0
22429737 -rw- 10030761 Wed Feb 4 10:05:20 2015 asr9k-bng-px.pie-5.2.2
22376230 -rw- 13912 Wed Feb 4 10:05:22 2015 asr9k-optic-px.pie-5.2.2
22429704 -rw- 13447606 Wed Feb 4 10:05:24 2015 asr9k-mgbl-px.pie-5.2.2
22429706 -rw- 37757434 Wed Feb 4 10:05:29 2015 asr9k-asr901-nV-px.pie-5.2.2
22429707 -rw- 227206056 Wed Feb 4 10:05:56 2015 asr9k-fpd-px.pie-5.2.2
22429708 -rw- 4823286 Wed Feb 4 10:05:58 2015 asr9k-doc-px.pie-5.2.2
22429709 -rw- 3625332 Wed Feb 4 10:06:00 2015 asr9k-services-px.pie-5.2.2
22429710 -rw- 233959013 Wed Feb 4 10:06:27 2015 asr9k-asr903-nV-px.pie-5.2.2
22429711 -rw- 1487556 Wed Feb 4 10:06:29 2015 asr9k-video-px.pie-5.2.2
22429739 -rw- 762808 Wed Feb 4 10:06:30 2015 asr9k-li-px.pie-5.2.2
22429742 -rw- 18987464 Wed Feb 4 10:06:33 2015 asr9k-mcast-px.pie-5.2.2
23440928 -rw- 493810592 Wed Feb 4 10:07:33 2015 asr9k-services-infra-px.pie-5.2.2
23440929 -rw- 27232034 Wed Feb 4 10:07:45 2015 asr9k-asr9000v-nV-px.pie-5.2.2
23440930 -rw- 395451764 Wed Feb 4 10:08:30 2015 asr9k-mini-px.pie-5.2.2
23440931 -rw- 15633579 Wed Feb 4 10:08:35 2015 asr9k-mpls-px.pie-5.2.2
23440932 -rw- 10930695 Wed Feb 4 10:08:39 2015 asr9k-k9sec-px.pie-5.2.2
23440933 -rw- 539910 Wed Feb 4 10:09:13 2015 asr9k-px-5.2.2.CSCur46253.pie
23440934 -rw- 4604945 Wed Feb 4 10:09:14 2015 asr9k-px-5.2.2.CSCur22750.pie
23440936 -rw- 1176749 Wed Feb 4 10:09:15 2015 asr9k-px-5.2.2.CSCuq89377.pie
22376181 -rw- 10826 Wed Feb 4 10:16:38 2015 sam_certdb
RP/0/RSP1/CPU0:ios#dir disk0:
Wed Feb 4 10:15:03.293 UTC
Directory of disk0:
46194 -r-- 2954492 Sat Nov 19 14:49:50 2044 .bitmap
17 -r-- 2084352 Sat Nov 19 14:49:50 2044 .inodes
18 -rw- 0 Sat Nov 19 14:49:50 2044 .boot
19 -rw- 0 Sat Nov 19 14:49:50 2044 .altboot
46199 drwx 4096 Sat Nov 19 14:49:51 2044 dumper
46200 -r-- 98304 Sat Nov 19 14:49:50 2044 .longfilenames
46201 drwx 4096 Wed Nov 19 14:58:47 2014 LOST.DIR
46202 drwx 4096 Wed Feb 4 10:02:05 2015 snmp
7438182 drwx 4096 Tue Feb 3 11:25:01 2015 asr9k-scfclient-4.3.4
46204 drwx 4096 Wed Feb 4 10:02:13 2015 cepki
46205 drwx 4096 Wed Feb 4 10:02:13 2015 eem_rdsfs
46206 drwx 4096 Wed Feb 4 10:14:55 2015 instdb
46207 drwx 4096 Tue Feb 3 08:44:32 2015 sm_rdsfs
46208 drwx 4096 Tue Feb 3 08:43:59 2015 rem_proxy
46209 drwx 4096 Tue Feb 3 08:44:19 2015 onepk_cli_rdsfs
25552469 drwx 4096 Tue Feb 3 11:25:01 2015 asr9k-diags-supp-4.3.4
25552484 drwx 4096 Tue Feb 3 11:25:01 2015 asr9k-ce-4.3.4
46290 drwx 4096 Tue Feb 3 11:25:12 2015 asr9k-fwding-4.3.4
771205 drwx 4096 Tue Feb 3 11:25:27 2015 asr9k-base-4.3.4
1568221 drwx 4096 Tue Feb 3 11:25:30 2015 asr9k-os-mbi-4.3.4
1568226 drwx 4096 Tue Feb 3 11:25:33 2015 asr9k-cpp-4.3.4
1632061 drwx 4096 Tue Feb 3 11:25:37 2015 iosxr-ce-4.3.4
1635838 drwx 4096 Tue Feb 3 11:25:37 2015 iosxr-diags-4.3.4
46218 drwx 4096 Wed Feb 4 10:02:02 2015 license
46219 drwx 4096 Wed Feb 4 10:01:54 2015 config
1635876 drwx 4096 Tue Feb 3 11:25:43 2015 iosxr-routing-4.3.4
46221 drwx 4096 Wed Nov 19 15:10:43 2014 var
46222 drwx 4096 Wed Nov 19 15:10:43 2014 virtual-instance
2119108 drwx 4096 Tue Feb 3 11:26:21 2015 iosxr-fwding-4.3.4
46224 drwx 4096 Wed Feb 4 10:01:52 2015 aaa
5066708 drwx 4096 Tue Feb 3 11:26:57 2015 iosxr-infra-4.3.4
6269457 drwx 4096 Tue Feb 3 11:26:58 2015 asr9k-mini-px-4.3.4
46227 -rw- 0 Wed Nov 19 15:17:31 2014 umass.log
46228 drwx 4096 Wed Nov 19 15:20:41 2014 sla
46229 -rw- 0 Wed Nov 19 15:20:56 2014 tar_report.txt
6269467 drwx 4096 Tue Feb 3 14:43:39 2015 iosxr-security-4.3.4
7305650 drwx 4096 Tue Feb 3 15:31:04 2015 asr9k-cpp-4.3.4.CSCum03261-1.0.0
6332114 drwx 4096 Tue Feb 3 14:43:39 2015 asr9k-k9sec-supp-4.3.4
6332117 drwx 4096 Tue Feb 3 14:43:39 2015 asr9k-k9sec-px-4.3.4
6332136 drwx 4096 Tue Feb 3 14:44:09 2015 asr9k-fpd-4.3.4
6432444 drwx 4096 Tue Feb 3 14:44:10 2015 asr9k-fpd-px-4.3.4
6432456 drwx 4096 Tue Feb 3 14:44:32 2015 asr9k-asr901-supp-4.3.4
6432462 drwx 4096 Tue Feb 3 14:44:33 2015 asr9k-asr901-nV-px-4.3.4
6432475 drwx 4096 Tue Feb 3 14:44:46 2015 asr9k-9000v-nV-supp-4.3.4
6432481 drwx 4096 Tue Feb 3 14:44:46 2015 asr9k-9000v-nV-px-4.3.4
6432494 drwx 4096 Tue Feb 3 14:44:58 2015 asr9K-doc-supp-4.3.4
6432661 drwx 4096 Tue Feb 3 14:44:58 2015 asr9k-doc-px-4.3.4
6332137 drwx 4096 Tue Feb 3 14:45:10 2015 iosxr-li-4.3.4
6432674 drwx 4096 Tue Feb 3 14:45:10 2015 asr9k-li-4.3.4
6487076 drwx 4096 Tue Feb 3 14:45:10 2015 asr9k-li-px-4.3.4
6487092 drwx 4096 Tue Feb 3 14:45:26 2015 iosxr-mcast-4.3.4
6822018 drwx 4096 Tue Feb 3 14:45:26 2015 asr9k-mcast-supp-4.3.4
6822058 drwx 4096 Tue Feb 3 14:45:26 2015 asr9k-mcast-px-4.3.4
6822076 drwx 4096 Tue Feb 3 14:45:41 2015 iosxr-mgbl-4.3.4
6920848 drwx 4096 Tue Feb 3 14:45:42 2015 asr9k-mgbl-supp-4.3.4
6920863 drwx 4096 Tue Feb 3 14:45:43 2015 asr9k-mgbl-px-4.3.4
7011072 drwx 4096 Tue Feb 3 14:45:58 2015 iosxr-mpls-4.3.4
7085767 drwx 4096 Tue Feb 3 14:45:58 2015 asr9k-mpls-px-4.3.4
7085779 drwx 4096 Tue Feb 3 14:46:11 2015 iosxr-service-4.3.4
7145333 drwx 4096 Tue Feb 3 14:46:12 2015 asr9k-service-supp-4.3.4
7215285 drwx 4096 Tue Feb 3 14:46:12 2015 asr9k-services-px-4.3.4
7215303 drwx 4096 Tue Feb 3 14:46:27 2015 iosxr-adv-video-4.3.4
7215426 drwx 4096 Tue Feb 3 14:46:27 2015 asr9k-adv-video-supp-4.3.4
7215452 drwx 4096 Tue Feb 3 14:46:28 2015 asr9k-video-px-4.3.4
6269465 drwx 4096 Tue Feb 3 14:59:23 2015 iosxr-adv-video-4.3.4.CSCum46796-1.0.0
7305561 drwx 4096 Tue Feb 3 14:59:23 2015 asr9k-px-4.3.4.CSCum46796-1.0.0
7305576 drwx 4096 Tue Feb 3 15:00:51 2015 iosxr-fwding-4.3.4.CSCum43188-1.0.0
7305638 drwx 4096 Tue Feb 3 15:00:51 2015 asr9k-px-4.3.4.CSCum43188-1.0.0
7305653 drwx 4096 Tue Feb 3 15:04:26 2015 asr9k-os-mbi-4.3.4.CSCui94441-1.0.0
7305660 drwx 4096 Tue Feb 3 15:04:28 2015 asr9k-base-4.3.4.CSCui94441-1.0.0
7305803 drwx 4096 Tue Feb 3 15:04:28 2015 asr9k-px-4.3.4.CSCui94441-1.0.0
6487081 drwx 4096 Tue Feb 3 16:25:58 2015 asr9k-fwding-4.3.4.CSCul93777-1.0.0
7438172 drwx 4096 Tue Feb 3 15:31:05 2015 asr9k-fwding-4.3.4.CSCum03261-1.0.0
6432487 drwx 4096 Tue Feb 3 15:31:05 2015 asr9k-px-4.3.4.CSCum03261-1.0.0
7305642 -rw- 126 Wed Feb 4 10:02:22 2015 sam_crldb
6432664 drwx 4096 Tue Feb 3 16:25:58 2015 asr9k-px-4.3.4.CSCul93777-1.0.0
7438154 -rw- 10826 Wed Feb 4 10:02:22 2015 sam_certdb
7760559 drwx 4096 Mon Feb 2 14:22:02 2015 syslog
52256 drwx 4096 Mon Feb 2 14:24:28 2015 np
02-04-2015 10:33 AM
That is correct, files such as pie's and smu's are not synced, only the package directories after the install add is performed.
Sam
02-04-2015 10:35 AM
Thanks Sam. That makes more sense to me now.
