Warning message
Too Large frames
Feb 3rd, 2015
Hi all,
I am getting high counters on ISL trunk ports across all my switches
There seem to be no errors but I get "Too large Frames" on the Transmit
and "Valid frames, too large" on the Receive, the MTU across all switches is 1500,
I do not see these issues on any other ports except the trunks, I am not sure if this is a problem,
does anybody have any idea if this is something I should be concerned about, unfortunately this is a remote location
so I am unable to attend the site to do a wireshark trace to see what these packets are?
Below are the show controllers and show interface output for one such port
Transmit GigabitEthernet1/0/11           Receive
   1985737654 Bytes                       1875094148 Bytes
      8481583 Unicast frames                 9035176 Unicast frames
       524296 Multicast frames                 43508 Multicast frames
       457112 Broadcast frames                 42376 Broadcast frames
            0 Too old frames              1587874771 Unicast bytes
            0 Deferred frames                8103346 Multicast bytes
            0 MTU exceeded frames            5484381 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames                   5 Minimum size frames
            0 8 collision frames             6327442 65 to 127 byte frames
            0 9 collision frames             1328933 128 to 255 byte frames
            0 10 collision frames             867097 256 to 511 byte frames
            0 11 collision frames             177976 512 to 1023 byte frames
            0 12 collision frames             255627 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames             163980 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
            3 64 byte frames                       0 Valid frames, too small
      2017248 127 byte frames
       265988 255 byte frames                      0 Too old frames
       207425 511 byte frames                      0 Valid oversize frames
       454576 1023 byte frames                     0 System FCS error frames
      1467674 1518 byte frames                     0 RxPortFifoFull drop frame
      5050077 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
core1#show interfaces gigabitEthernet 1/0/11
GigabitEthernet1/0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is b838.6176.fd0b (bia b838.6176.fd0b)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:29, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 411000 bits/sec, 231 packets/sec
  5 minute output rate 2240000 bits/sec, 234 packets/sec
     9244336 packets input, 1907654152 bytes, 0 no buffer
     Received 86053 broadcasts (43663 multicasts)
     0 watchdog, 43663 multicast, 0 pause input
     9587399 packets output, 10729144282 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Thanks in advance any suggestions are welcome
Leo Laohoo Tue, 02/03/2015 - 20:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I wouldn't be worried about that.  You'll see this counter go up on Trunk ports:  Dot1Q and ISL.
