Warning message
management Interface not responding to telnet or pings
Feb 3rd, 2015
Hi all,
I have a curious issue, I lose telnet access and cannot even ping the management interface of all the cisco switch in a flat network,
I have a core 2750x with 5 trunks using ISL to 5 x3560x, Traffic seems to pass through these switches fine as I have a wireless controller
connected to the core and AP's hanging of these switches and all AP's never lose connectivity with the controller, The AP sends Hello packets every 30 seconds and there will be notifications if these are not received.
Sometimes I have no issues and can telnet from the core or any other switch to one another,
when I log in the next day or even after a few hours the problem manifests, There are no error or dropped packet on all switches, port utilization and CPU utilization are low, Also I have set up port forwarding on the firewall to give me remote access via telnet to the switches this always works?
whilst this problem occurs I can telnet to any switch from the WAN but cannot telnet locally from the switches CLI
any idea's what may be causing this ?
any help would be appreciated
Overall Rating: 5 (1 ratings)
sulinder1 Tue, 02/03/2015 - 21:22
sorry the core switch is a 3570x to amend to my remarks above
nate fitzgerald Wed, 02/11/2015 - 08:48
Can you see the 3750X IP address from the other switches using CDP ??
Do you have the following ?
SVI (switched virtual interface for network connectivity)
Interface vlan 1 <----- assuming you are using vlan 1 since you only have one subnet on the network as you mentioned above
ip address 10.1.1.1 255.255.255.0
no shut
TELNET/SSH ACCESS
Line vty 0 15
login ( or login local)
password cisco1234 (if not using local credentials)
transport input all
exit
Verify you can at least ping the 3750x from the other switches, there could be something blocking it, if not can you post the running config from the 3750x and the running config from the switch/switches you are trying to telnet from.
sulinder1 Sat, 02/14/2015 - 20:36
Hi Nate,
There are no firewall or ACL's in place to block wired traffic,
I have remotely logged in via telnet and got the running config and cdp  neighbors report below,
all 5 switches are configured the same with trunk ports connected the this switch 192.168.7.254 (3750x), They all have a mgt IP on vlan1 192.168.7.254-249)via telnet via port forwarding on the firewall, once I connect to the core switch or any other via a remote session I cannot telnet from one switch to another?
The switchport mode on the trunk ports is set to "dynamic desirable" so they use cisco propriety ISL protocol for trunking to the other cisco switches.
As mentioned I can connect to all switches remotely via telnet through the firewall
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.15 15:09:46 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
core1>enable
Password:
core1#show running-config
Building configuration...
Current configuration : 3281 bytes
! No configuration change since last restart
! NVRAM config last updated at 14:41:53 UTC Tue Feb 3 2015
version 12.2
no service pad
hostname core1
boot-start-marker
boot-end-marker
enable secret 5 $1$xk7W$yvKinhgotTezJlDIW6WrC1
enable password xxxx
no aaa new-model
switch 1 provision ws-c3750x-12s
system mtu routing 1500
crypto pki trustpoint TP-self-signed-1635187968
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1635187968
 revocation-check none
 rsakeypair TP-self-signed-1635187968
crypto pki certificate chain TP-self-signed-1635187968
 certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363335 31383739 3638301E 170D3933 30333031 30303031
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36333531
  38373936 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B25B 0C075343 DD51B86D 6871C9BF 79F552EE DDBC1B3D 58C8D4A0 2EC6063C
  D77D72AC FBD2583A 68F04CFB 3E2FAC06 19409670 0FB57C71 96118E7E A21BF5D9
  61B22332 EE6921B0 5D93C879 67A0AC6F 413EDAD6 8C815BCC A7DE1134 56735697
  A693494E E1FEFBA8 6A246A32 F066E721 701601E6 03F8E255 EFBD0B70 DE028D19
  DCC10203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05636F72 6531301F 0603551D 23041830 16801458 BE03F383
  B255507B 93814AD7 0027E8C3 3A160E30 1D060355 1D0E0416 041458BE 03F383B2
  55507B93 814AD700 27E8C33A 160E300D 06092A86 4886F70D 01010405 00038181
  0054608D 266B667D AE9114ED E75B2D73 CF1A4B2B 4C770E90 6DDB7162 60E90E3D
  C9338345 5EF3DD54 9E35C50A 7164910A 84219F96 0826AF3C C1FAD7CD B9789857
  EF144F76 8B7FEBD2 041B2393 D6D58458 7F6078B2 6211D6EA 19AB1F56 372CE2B9
  D546D232 FE962CE6 832D46F6 4D51ED69 8765CC77 90882B2C B72825D1 B50F757E E8
   quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
 switchport mode dynamic desirable
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
 ip address 192.168.7.254 255.255.248.0
ip default-gateway 192.168.1.254
ip http server
ip http secure-server
logging esm config
line con 0
line vty 0 4
 password xxxxxx
 login
 length 0
line vty 5 15
 password xxxxxx
 login
end
core1#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
switch2          Gig 1/0/11        163              S I   WS-C3560X Gig 1/1
switch3          Gig 1/0/7         157              S I   WS-C3560X Gig 1/1
switch1          Gig 1/0/5         168              S I   WS-C3560X Gig 1/1
switch4          Gig 1/0/9         150              S I   WS-C3560X Gig 1/1
switch5          Gig 1/0/3         148              S I   WS-C3560X Gig 1/1
core1# exit
thsnks
Jerry Paul Wed, 02/04/2015 - 08:45
  • Community Spotlight Award,
    Best Publication, May 2015
Read your question again...2750x switch does not exist. It will be 3750x.
If you have any dedicated/Live IP then you can telnet your network from WAN.
You will need to assign an IP to switch and that IP must be a live IP.
sulinder1 Wed, 02/04/2015 - 13:02
hi Jerry,
i have no problems to telnet to the switches via the WAN, problem is telneting from one switch to another, sometimes works and sometimes cant connect even wont respond to pings
Jerry Paul Wed, 02/11/2015 - 07:14
First of all you must assign an IP address to VLAN on every switch. Then set tellnet password and enable password.
Then you will be able to access LAN switches.
nate fitzgerald Tue, 02/10/2015 - 13:55
The other switches you are trying to telnet from are they in the same subnet as you core switch for instance are trying to telnet from switch 1 IP address 10.1.1.1 to switch 2 10.2.2.2 ? if so then since the subnet is different you would need the ip default-gateway command added to the switch, or since these are Layer 3 switches and if you have the command ip routing enabled, the you can add the ip route statement, that way the switches know how to get from one subnet to another
sulinder1 Tue, 02/10/2015 - 22:37
Hi Nate, all switches are on the same subnet just a layer 2 environment with a single gateway for my remote access,
thanks
LJ Gabrillo Tue, 02/10/2015 - 17:42
  • Silver, 250 points or more
Can we get the logs of the devices.
#show cdp neighbors            -Helps us see where/how you connected them
A network diagram as well, that would be nice
sulinder1 Tue, 02/10/2015 - 22:39
I am currently on-site in another state and have access controls on the FW so can only log into the switches when I am back in the office as they are also a another location, I will get the config to you next week, that's for looking at this, will update you early next week
regards
Sulinder
sulinder1 Sat, 02/14/2015 - 20:29
Hi all,
Password:
core1>enable
Password:
version 12.2
no service pad
hostname core1
boot-start-marker
boot-end-marker
no aaa new-model
   quit
 no ip address
interface Vlan1
ip http server
logging esm config
line con 0
line vty 0 4
 password xxxxxx
 login
 length 0
line vty 5 15
 password xxxxxx
 login
end
core1# exit
sulinder
sulinder1 Sat, 02/14/2015 - 20:42
Oh yea forgot the network topology is just a star the all other 5 switches just connect to the 3750,
no loops in the network pretty basic setup,
Basically 5 different building connected to the core, main building which provides internet access,
seems traffic is passing through the switches fine without any problems
