02-06-2015 12:29 AM
Hi All,
we have 2 ASR9010 IOS XR version 6.0 at 2 sites and would like to span 2 VLANs across the MPLS network using VPLS. The config is below
PE1
interface bundle-eth2.200 l2transport
encapsulation dot1q 200 , 300
l2vpn
bridge group 2
bridge-domain Spansites
vfi 1
neighbor 10.1.1.1 pw-id 200
PE2 config
l2vpn
bridge group 2
vfi 1
neighbor 10.1.2.1 pw-id 200
Both CEs are running etherchannel and trunk.
will the config above work? will the ASR forward incoming frame from VLAN 200(or 300) to PW with tag 200(or 300) or untag?
Tao
02-06-2015 10:31 PM
basic config require
rewrite ingress tag pop 1 symmetric
on l2transport subinterface, so you config will not work.
02-07-2015 04:46 PM
I have pass trafic with and without the pop symetric in the l2tranpsort sub-interface, not sure if the PW that you are showing are /32, as far as I know that is a MOST.
02-08-2015 04:53 AM
in principle this config will work but I dont think it is a recommended approach, let me explain.
In your scenario you are preserving the tag, so the single pw can carry both and on the remote side there is no issue either.
since you only have one AC and one PW, you might as well go for a cross connect. this is faster in the fowarding path and also saves mac learning resources, no concern about flooding or unnecessary replication when the received packet is a bcast or mcast.
in Xconn, the receive packet is just encapped and sent over, which is therefore much faster in terms of ucode cycles.
config for that would be:
l2vpn
xconn group BLA
p2p MINE
int bundle-e100.20
neighbor 10.1.2.1 pw-id 100
I would either do port mode, considering you mention trunk on the CE side.
Or I would create specific p2p's for those vlans you want to tunnel across.
But you can also leave them like this of course.
If you create individual p2p's or BD's for each vlan separately you can use the pop tag symmetric, which saves a few bytes vlan overhead on the mpls transport.
regards
xander
02-08-2015 02:43 PM
Thank you everyone for your response.
in the XR platform the tag will not be popped at ingress interface and the incoming frame with tag will be forwarded to PW. the IOS platform will pop the incoming tag and forward untag frame to PW.
For the Xconnect vs BD, that is for future use as that leaves room to span these vlans across multiple sites.
For each vlan per PW vs multiple vlan(ambiguous encapsulation) per PW, this in an interesting point. when using ambiguous encap, we have overhead. However, it is simple in term management if we have 100+ VLANs to span. Port mode is an option but it will be an issue if some vlans need to translate while others don't.
Xander, 100% aggree with you in the example above, port base or 2 PWs will be better choice.
Once again, thanks everyone.
The
