02-06-2015 02:32 AM - edited 03-10-2019 10:25 PM
Dear guys,
I deployed Cisco ISE for Network Access Control. My topology as described as attached image. I configured Cisco ISE as Radius Server for Client Access Control. But, I got some problems such as:
I would greatly appreciate any help you can give me in working this problem.
Have a nice day,
Thanks and Regrads,
02-06-2015 09:22 AM
Just to clarify, you have of course created your switches in the device list in ISE, and used the samme password both in the switch and in ise for radius ?
How does your radius config look in your switches ?
What software are you running on the switches ?
02-18-2015 07:14 AM
Share your switch config..following is sample switch config and check NAD OS compatibility with ISE
http://www.cisco.com/c/en/us/td/docs/security/ise/1-3/compatibility/ise_sdt.html
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
radius-server host isexxxxx auth-port 1812 acct-port 1813
radius-server key xxxx
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
ip radius source-interface gxx
dot1x system-auth-control
interface range gxx
switchport mode access
authentication port-control auto
dot1x pae authenticator
mab
authentication open
authentication host-mode multi-auth
switchport access vlan x
switchport voice vlan x
authentication order mab dot1x
authentication priority dot1x mab
no shutdown
end
ip device tracking
ip dhcp snooping
03-03-2015 04:59 AM
Sorry for late reply.
Here is my switch config.
Current configuration : 8630 bytes
My switch version is WS-2960 12.2(55)SE5 C2960-LANBASEK9-M |
