02-10-2015 02:06 AM - edited 07-05-2021 02:28 AM
Hi Guys,
i have a wlc 2504 with 7.6.130
My management ip address is 192.168.1.1/24 and i have an interface on the wlc with ip address 192.168.2.1
From a PC(wired) with ip address 192.168.2.x (network are routed) i cannot access https://192.168.1.1 when i configure on the wlc an interface with ip address 192.168.2.1
It's look like i cannot access wlc from a network defined on the wlc.
Can you help me in resolving this issue?
Solved! Go to Solution.
02-10-2015 04:37 AM
That is by design. The WLC does not allow access from a configures interface other than management by default.
If you need to access the WLC from a configures interface other than management you need to issue the command:
config network mgmt-via-dynamic-interface enable
HTH,
Steve
02-10-2015 04:37 AM
HTH,
Steve
