02-10-2015 11:35 PM - edited 03-01-2019 12:01 PM
Dear community, just fyi
I just run at a customer site in the following issue: New chassis with 4 new B200-M4 and local 300GB SAS Toshiba disks, firmware 2.2.3d.
SP association failed, error message : Raid controller L2/L3 cache failure,.... see attachment
We removed discs, Raid controller was ok
Decommission / recommission, didn't solve the issue.....
Finally I learned that there is a known problem, which is related to Toshiba discs, Seagate discs seem to work !
Similar cases with C-Series M4 servers have been reported.
Kind Regards
Walter.
03-06-2015 03:50 AM
Hi Walter,
got the same problem here. Cisco B200 M4 with 2 Toshiba 300GB Harddisk-Drives.
Drives got "Failed" State within the RAID-Controller. I'm currently unable to configure the server and to bind a Service Profile to that hardware.
Removing the disks and everything works fine.
Did you ever got a resolution to this case ??
Did you contact the TAC ??
Thanks for help
Kind regards,
Oliver Hien
03-06-2015 07:01 AM
Hi Oliver
This seems to be a known problem; my customers just had to RMA their Toshiba HDD, replacing them e.g. by Seagate. Meanwhile their is also a Field Notice, which I believe is related to this problem.
Title: | |
Description: | Certain hard disk drives (HDDs) with new firmware might be automatically downgraded by Unified Computing System (UCS) Manager, which causes the drive to become unusable. The issue affects certain hard drives manufactured by Toshiba under the Product IDs listed in the Products Affected section. The issue affects UCS B-Series and UCS C-Series, only in environments managed through UCS Manager Version 2.2(3).
06-24-2015 07:46 AM
06-24-2015 09:48 AM
Hi Shyam
The only solution is to RMA (replace) the disk !
Walter.
06-24-2015 02:00 PM
Yes, open a TAC case and have them confirm you ran into this issue and make reference to this bug ID https://tools.cisco.com/bugsearch/bug/CSCus51733/?reffering_site=dumpcr ; same as the Field Notice Walter posted above... that way TAC will know they need to verify that and go from there...
-Kenny
