02-11-2015 01:57 AM - edited 03-15-2019 06:05 AM
Hi All,
i have finesse 10.5 integrated with UCCE 10.5. i was able to login with finesse Agent desktop and able to receive and make call. But today i am facing one issue when i am trying to login, it gives error. i have attached the error.
Mukesh
02-11-2015 06:57 AM
Is this for all agents? Have you tried to login using CTIOS to rule out Finesse as the problem?
david
02-11-2015 11:06 PM
Hi All,
Issue got resolved. issue was with awdb communication issue and just because of this Agents were not getting authenticated. I just stop the services on AW and PGs. Restarted the server and services. It started working fine.
Thanks for all suggestions.
Mukesh Singh
02-11-2015 10:07 PM
Hi Mukesh,
What is the error code you are seeing in CG logs and pim logs. that will give some more idea about the issue.
Sasikumar.
