02-15-2015 01:59 PM - edited 03-10-2019 10:27 PM
Hi.
I'm trying to use Anyconnect 4 as a 802.1x supplicant replacement.
I'm trying to make a profile with Anyconnect Profile Editor, where the settings are WPA2 Enterprise where both machine and user must use certificates.
I have downloaded the CA certificate from my Certificate Server, converted it to PEM and loaded it into the Profile Editor.
But when I try to use the generated configuration.xml, I get this error:
No valid certificates available. Please insert a smart card or install a valid certificate.
If I load the xml file into Notepad++ I see that the certificate path is set to the path on the hard drive where I loaded it from, ie. D:\Certificate.pem
Shouldn't that point to the Certificate Store instead?
But even if I correct the path to something on the local hard drive, I still get the same error.
So, any tips on how to use the Profile Editor correctly?
Thank you.
10-19-2015 05:20 AM
I have this same issue. Did you solved it ?
thanks.
Murilo
10-21-2015 08:42 AM
Hi.
Sadly, I did not.
There does not seem to be a lot of users using Anyconnect as a supplicant replacement.
At least they do not hang around here.
03-06-2024 01:15 PM
I'm running into the same issue in 2024 and trying to use AnyConnect as a supplicant for 802.1x Authentication to test it in my lab environment. I don't find anything type of documentation that helps online.
03-06-2024 02:04 PM
Secure Client (formerly AnyConnect) NAM is an older method for EAP Chaining using EAP-FASTv2. Much of the older documentation has been retired, so it will likely be difficult to find. The best documentation available is in the Secure Client Admin Guide.
If you are mainly wanting to implement EAP Chaining, the recommended way to do that would be using the native TEAP support in newer versions of Windows 10/11.
