Unity 10.5.1.10000-7 to 10.5.1.11901-1 failed
kelvinffhan
Hi All,
Anyone facing the problem below?
Am I hitting the bugs below? For me it is just straight forward upgrade, but anyhow it is failed.
CSCus33633
CSCus33633
Failed Logs :
admin:utils system switch-version
Active Master Version: 10.5.1.10000-7
Inactive Master Version: 10.5.1.11901-1
If you are switching to an earlier release, you must run:
utils dbreplication reset all
from the publisher after all the nodes are switched over.
Do you really want to switch between versions ?
Enter (yes/no)? yes
 Switching Version and Restarting the Appliance ...
Switch version duration can vary depending on the database size
and platform configuration.  Please continue to monitor the
switchover process from here.
Waiting ...............................................................................................
Operation failed
ERROR: Sync after switch version failed
8 Replies 8
Aman Soi
there was a similar discussion on same problem.I suggest opening TAC case and share the resolution.
https://supportforums.cisco.com/discussion/12424016/unity-connection-upgrade-1051-1052-issue
regds,
aman
Thanks Aman, I did open a TAC. Will post the result accordingly
Anirudh Mavilakandy
If you have locales installed, then upgrade from any version of 10.x will fail.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/release/notes/10_5_2cucrn.html#pgfId-1957559
  • If you want to upgrade a Unity Connection 10.x server on which the language files are installed to Unity Connection 10.5(2), do the following steps:
– Download and install the ciscocm.cuc_10.5.2_preupgrade.cop.sgn cop file fromhttps://software.cisco.com/download/release.html?i=!y&mdfid=286268851&softwareid=282204704&release=COP-Files&os=.
– Uninstall the 10.5(1) language files.
– Upgrade the Unity Connection server to release 10.5(2).
– Install the 10.x language files.
Thanks for your. I do not have any locale installed.
Below is the TAC replied.
015-02-17 13:16:45 shared memory not initialized for INFORMIXSERVER 'ciscounityb'
2015-02-17 13:16:45 ++ for mount in '"${mount_points[@]}"'
 /partB/partB/spare
2015-02-17 13:16:45 ++ [[ 1 == 0 ]]
2015-02-17 13:16:45 +++ basename /partB/opt/cisco/connection/lib/install/uc_version_switch_passive
2015-02-17 13:16:45 ++ echo 'uc_version_switch_passive failed.'
2015-02-17 13:16:45 uc_version_switch_passive failed.
2015-02-17 13:16:45 ++ exit 1
Looks like shared memory not initialised for informix server.
Is the issue finally resolved?
regds,
aman
Hi, I need to gather the logs to CIsco TAC for further analyze. Bear with me :)
From what Cisco TAC mentioned that my DBreplication has broken, he did a "remote support" which only applied to Cisco TAC access to resolve my problem.
He did mentioned "rebooting" the server may also resolve the problem as well.
thanks for updates[+5]
regds,
aman
