02-17-2015 03:20 AM - edited 03-19-2019 09:12 AM
I have the application Cisco UC Integration for Microsoft Lync 9.7.6 (currently the latest version) installed on my customer's computers.
There is still the bug CSCuq52762 : "CUCI Lync display name is in format Username@" despite that it was mark as "closed" in the release note 9.7.5.
Am I the only one with this issue? Did someone found a workaround?
Thank you.
Thomas.
02-17-2015 05:07 AM
Hi Thomas,
The bug was terminated in December without a fix and the workaround listed in bug is also not a viable one. You should contact TAC for this particular issue.
Manish
04-09-2015 01:36 AM
Hi Thomas,
configure a jabber-config.xml file and include the presence domain.
<Directory>
<PresenceDomain>cisco.com</PresenceDomain>
</Directory>
After that, the UDS Service is able to associate the CUCiKLync user with die cucm user.
Good luck!
