02-17-2015 04:05 PM - edited 07-05-2021 02:31 AM
Are there no commands/method(s) available to see the SSID's as well as the type of encryption each one is using? So far the only way I have been able to find is:
- show dot11 bssid (But this only shows the SSID) and then have to do show runn to see what each SSID is using such as WPA or WEP, TKIP etc
Need to check this on a whole buncha AP's but can't really script it if there is no single command available.
02-17-2015 05:32 PM
That is the way you can check the authentication types, similar way you apply per ssid
02-18-2015 07:28 AM
Thanks I do know that, I wanted to see if there is another better way to accomplish this though.
02-18-2015 10:09 AM
The easiest way is either through the GUI, you will have a summary of each SSID with its encryption.
If you don't want to issue a show run, then the most easy way will be to run a command like this:
For the encryption (per radio):
ap#show run interface dot11Radio 0 | inc encryption
ap#show run interface dot11Radio 1 | inc encryption
For the SSID:
ap#show run | sec ssid
Beside of this, there is no other command that I am aware of
02-18-2015 02:27 PM
Thank you that is much better. Shame that there isn't a specific command for that. I guess with the controller based AP's now it isn't needed any more.
