Please follow configuration example to make your ports on ASA as a trunk mode and ASA should be routed mode and if you require any dynamic nat or static-nat you can do so as well.
Please make sure, you have one separate vpc extending to primary ASA and another vpc extending to secondary ASA.
interface GigabitEthernet0/2
channel-group 1 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface Port-channel1
port-channel load-balance src-dst-ip-port
nameif inside
security-level 100
ip address 10.10.2.2 255.255.255.252
Now should you require a DMZ interface, then create a subnet interface from port-channel interface.
interface Port-channel1.50
description VLAN-50
vlan 50
nameif dmz
security-level 50
ip address 10.10.30.2 255.255.255.0
You would treat ASA connection to VPC on 7K, just like any other fabric extenders connection.
Hope that answer your question.
Rizwan Rafeek
