02-20-2015 10:05 AM - edited 07-05-2021 02:33 AM
Hello Forum Team;
I had to break an HA pair (version 7.6.130.0) in order to upgrade (due to mismatch in Build-type) and now need to pair back the HA pair. SSO is enabled again on both WLC's, one primary and the other secondary. The secondary WLC is connected, but powered off. I will proceed to power on the secondary box:
Does this will cause the primary unit to reboot or the secondary will just come up as secondary-hot standby?
Thanks in advanced for your support guys!
02-23-2015 03:21 AM
After you enable HA, the primary and secondary controllers are rebooted. During the boot process, the role of the primary controller is negotiated as active and the role of the secondary controller as standby-hot. After a switchover, the secondary controller becomes the active controller and the primary controller becomes the standby-hot controller. After subsequent switchovers, the roles are interchanged between the primary and the secondary controllers. The reason for switchovers are either because of manual trigger or a controller or network failure.
The following are some guidelines for high availability:
02-24-2015 05:44 AM
Hello and thanks for your reply;
That is what documentation says but it is not my actual scenario.
Thanks again for your support.
