02-21-2015 02:59 AM - edited 07-05-2021 02:33 AM
Hello Everyone,
I am having Cisco 2504 WLC. I want to use radius authentication on one of my SSID's. Whenever I try to connect to the SSID having radius authentication enabled I am unable to connect to that SSID.
Anyone aware what can be the issue? My radius server is running on Windows Server.
02-22-2015 11:44 AM
What does radius logs says about this ?
Also if you get "debug client <client_mac_address>" output that will give you a hint what's missing.
Also attach "show wlan <wlan_id>" output to see the config of WLAN as well.
Rasika
*** Pls rate all useful responses ****
02-22-2015 11:16 PM
Made some changes on the radius server and then it started to work
