I have two ASR9k with ISM modules running the CGN NAT service
I have configured two /21 pools on each box , which means 4096 IP address for each box , when I check the statistics
RP/0/RSP0/CPU0:CGN-3G-NAT1#show cgn nat44 nat1 statistics
Statistics summary of NAT44 instance: 'nat1'
Pool address used: 4096
RP/0/RSP0/CPU0:CGN-3G-NAT2#show cgn nat44 nat1 statistics
Pool address used: 3876
Why the 4096 is reduced on the second box ? and the value varies but did not reach even 4000 ?
Mohammad
