02-23-2015 06:01 AM - edited 03-14-2019 02:28 PM
Hi ,
we have integrated CUIC 10.0 with PCCE 10.0 and trying to configure live data report of agent. But we are not getting any data on the report.
Couldn't find any configuration document for this in cisco site.Not understanding how the live data is getting communicated to ICM Call server and PG without any reference of this system in CUIC.
Please clarify if somebody knows about this and help to solve the issue.
sethu
02-23-2015 08:10 AM
02-23-2015 09:51 AM
Sorry i don't have access to the system at this moment.But i did a complete verification on this.We could see JMS data source with url pointing to CUIC ip address and i verified the test connect and it is successful.
we are able to generate both historical and normal real time report.Only have an issue with live data.
sethu
02-24-2015 06:05 AM
Hi David,
I have attached the screen shot of Data Sources.Also seeing following logs,
ExistsBuilderImpl$2.call(ExistsBuilderImpl.java:149)
at com.netflix.curator.framework.imps.ExistsBuilderImpl$2.call(ExistsBuilderImpl.java:138)
at com.netflix.curator.RetryLoop.callWithRetry(RetryLoop.java:85)
at com.netflix.curator.framework.imps.ExistsBuilderImpl.pathInForeground(ExistsBuilderImpl.java:134)
at com.netflix.curator.framework.imps.ExistsBuilderImpl.forPath(ExistsBuilderImpl.java:125)
at com.netflix.curator.framework.imps.ExistsBuilderImpl.forPath(ExistsBuilderImpl.java:34)
at storm.trident.topology.state.TransactionalState.setData(TransactionalState.java:57)
at storm.trident.topology.MasterBatchCoordinator.sync(MasterBatchCoordinator.java:172)
at storm.trident.topology.MasterBatchCoordinator.fail(MasterBatchCoordinator.java:132)
at backtype.storm.daemon.executor$fail_spout_msg.invoke(executor.clj:316)
at backtype.storm.daemon.executor$eval9308$fn$reify__9312.expire(executor.clj:376)
at backtype.storm.utils.RotatingMap.rotate(RotatingMap.java:56)
at backtype.storm.daemon.executor$eval9308$fn__9309$tuple_action_fn__9315.invoke(executor.clj:381)
at backtype.storm.daemon.executor$mk_task_receiver$fn__9299.invoke(executor.clj:348)
at backtype.storm.disruptor$clojure_handler$reify__6950.onEvent(disruptor.clj:43)
at backtype.storm.utils.DisruptorQueue.consumeBatchToCursor(DisruptorQueue.java:84)
at backtype.storm.utils.DisruptorQueue.consumeBatch(DisruptorQueue.java:46)
at backtype.storm.disruptor$consume_batch.invoke(disruptor.clj:59)
at backtype.storm.daemon.executor$eval9308$fn__9309$fn__9321$fn__9350.invoke(executor.clj:479)
at backtype.storm.util$async_loop$fn__5734.invoke(util.clj:377)
at clojure.lang.AFn.run(AFn.java:24)
at java.lang.Thread.run(Thread.java:619)
2015-02-23 22:57:28,607 - INFO [pool-31-thread-1:logging$eval5325$fn__5331@270] - 0000000699: 172.16.6.198: Feb 23 2015 22:57:28.606 +0530: %CCBU_DATAPROCESSING-3-Storm Spout: %[server_id=pg1][value=Machine Service List null or empty]: Spout UCCE Configuration - Spout end point configuration error
2015-02-23 22:57:28,607 - INFO [pool-31-thread-1:logging$eval5325$fn__5331@270] - 0000000700: 172.16.6.198: Feb 23 2015 22:57:28.607 +0530: %CCBU_DATAPROCESSING-6-Storm Spout: %[server_id=pg1][value=Invalid number of records = 0]: Spout UCCE Configuration - Spout end point configuration
2015-02-23 22:57:28,611 - INFO [pool-29-thread-1:logging$eval5325$fn__5331@270] - 0000000701: 172.16.6.198: Feb 23 2015 22:57:28.610 +0530: %CCBU_DATAPROCESSING-3-Storm Spout: %[server_id=router][value=Machine Service List null or empty]: Spout UCCE Configuration - Spout end point configuration error
2015-02-23 22:57:28,611 - INFO [pool-28-thread-1:logging$eval5325$fn__5331@270] - 0000000702: 172.16.6.198: Feb 23 2015 22:57:28.610 +0530: %CCBU_DATAPROCESSING-3-Storm Spout: %[server_id=pg2][value=Machine Service List null or empty]: Spout UCCE Configuration - Spout end point configuration error
2015-02-23 22:57:28,611 - INFO [pool-29-thread-1:logging$eval5325$fn__5331@270] - 0000000703: 172.16.6.198: Feb 23 2015 22:57:28.611 +0530: %CCBU_DATAPROCESSING-6-Storm Spout: %[server_id=router][value=Invalid number of records = 0]: Spout UCCE Configuration - Spout end point configuration
2015-02-23 22:57:28,706 - INFO [Camel (camel-4) thread #9 - timer://tempesta-jms-timer:logging$eval5325$fn__5331@270] - 0000000704: 172.16.6.198: Feb 23 2015 22:57:28.706 +0530: %CCBU_DATAPROCESSING-4-CamelService: %[operation_error_desc=StatusPublishRoute encountered an errororg.springframework.jms.UncategorizedJmsException: Uncategorized exception occured during JMS processing; nested exception is javax.jms.JMSException: Error while attempting to add new Connection to the pool; nested exception is javax.jms.JMSException: Could not connect to broker URL: tcp://localhost:61616. Reason: java.net.ConnectException: Connection refused
at org.springframework.jms.support.JmsUtils.convertJmsAccessException(JmsUtils.java:316)
at org.springframework.jms.support.JmsAccessor.convertJmsAccessException(JmsAccessor.java:168)
at org.springframework.jms.core.JmsTemplate.execute(JmsTemplate.java:469)
at org.apache.camel.component.jms.JmsConfiguration$CamelJmsTemplate.send(JmsConfiguration.java:171)
at org.apache.camel.component.jms.JmsProducer.doSend(JmsProducer.java:415)
at org.apache.camel.component.jms.JmsProducer.processInOnly(JmsProducer.java:369)
at org.apache.camel.component.jms.JmsProducer.process(JmsProducer.java:145)
at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:73)
at org.apache.camel.processor.SendProcessor$2.doInAsyncProducer(SendProcessor.java:122)
at org.apache.camel.impl.ProducerCache.doInAsyncProducer(ProducerCache.java:298)
at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:117)
at org.apache.camel.processor.DelegateAsyncProcessor.processNext(DelegateAsyncProcessor.java:99)
at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:90)
at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:72)
at org.apache.camel.processor.interceptor.TraceInterceptor.process(TraceInterceptor.java:91)
at org.apache.camel.processor.RedeliveryErrorHandler.processErrorHandler(RedeliveryErrorHandler.java:335)
at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:220)
at org.apache.camel.processor.RouteContextProcessor.processNext(RouteContextProcessor.java:46)
at org.apache.camel.processor.interceptor.DefaultChannel.process(DefaultChannel.java:308)
at org.apache.camel.processor.FilterProcessor.process(FilterProcessor.java:58)
at org.apache.camel.processor.Pipeline.process(Pipeline.java:117)
at org.apache.camel.processor.Pipeline.process(Pipeline.java:80)
at org.apache.camel.processor.UnitOfWorkProcessor.processAsync(UnitOfWorkProcessor.java:150)
at org.apache.camel.processor.UnitOfWorkProcessor.process(UnitOfWorkProcessor.java:117)
at org.apache.camel.processor.RouteInflightRepositoryProcessor.processNext(RouteInflightRepositoryProcessor.java:48)
at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:99)
at org.apache.camel.processor.DelegateAsyncProcessor.process(DelegateAsyncProcessor.java:86)
at org.apache.camel.component.timer.TimerConsumer.sendTimerExchange(TimerConsumer.java:135)
at org.apache.camel.component.timer.TimerConsumer$1.run(TimerConsumer.java:63)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
Caused by: javax.jms.JMSException: Error while attempting to add new Connection to the pool
at org.apache.activemq.util.JMSExceptionSupport.create(JMSExceptionSupport.java:35)
at org.apache.activemq.pool.PooledConnectionFactory.createConnection(PooledConnectionFactory.java:216)
at org.apache.activemq.pool.PooledConnectionFactory.createConnection(PooledConnectionFactory.java:195)
at org.springframework.jms.support.JmsAccessor.createConnection(JmsAccessor.java:184)
at org.springframework.jms.core.JmsTemplate.execute(JmsTemplate.java:456)
... 59 more
Caused by: javax.jms.JMSException: Could not connect to broker URL: tcp://localhost:61616. Reason: java.net.ConnectException: Connection refused
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQConnection(ActiveMQConnectionFactory.java:286)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQConnection(ActiveMQConnectionFactory.java:230)
at org.apache.activemq.ActiveMQConnectionFactory.createConnection(ActiveMQConnectionFactory.java:178)
at org.apache.activemq.pool.PooledConnectionFactory.createConnection(PooledConnectionFactory.java:247)
at org.apache.activemq.pool.PooledConnectionFactory$1.makeObject(PooledConnectionFactory.java:131)
at org.apache.activemq.pool.PooledConnectionFactory$1.makeObject(PooledConnectionFactory.java:111)
at org.apache.commons.pool.impl.GenericKeyedObjectPool.addObject(GenericKeyedObjectPool.java:1668)
at org.apache.activemq.pool.PooledConnectionFactory.createConnection(PooledConnectionFactory.java:214)
... 62 more
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at org.apache.activemq.transport.tcp.TcpTransport.connect(TcpTransp
2015-02-23 22:57:28,707 - INFO [Camel (camel-4) thread #9 - timer://tempesta-jms-timer:logging$eval5325$fn__5331@270] - ort.java:484)
at org.apache.activemq.transport.tcp.TcpTransport.doStart(TcpTransport.java:447)
at org.apache.activemq.util.ServiceSupport.start(ServiceSupport.java:53)
at org.apache.activemq.transport.InactivityMonitor.start(InactivityMonitor.java:126)
at org.apache.activemq.transport.TransportFilter.start(TransportFilter.java:58)
at org.apache.activemq.transport.WireFormatNegotiator.start(WireFormatNegotiator.java:72)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQConnection(ActiveMQConnectionFactory.java:266)
... 69 more
]: Camel Service Error
2015-02-23 22:57:28,708 - INFO [Camel (camel-4) thread #9 - timer://tempesta-jms-timer:MarkerIgnoringBase@159] - 0000000170: 172.16.6.198: Feb 23 2015 22:57:28.708 +0530: %_DEFAULTERRORHANDLER-3-org.apache.camel.processor.DefaultErrorHandler: Failed delivery for (MessageId: ID-pccuic-srvprcce-com-54769-1424709896264-3-7647 on ExchangeId: ID-pccuic-srvprcce-com-54769-1424709896264-3-7646). Exhausted after delivery attempt: 1 caught: org.springframework.jms.UncategorizedJmsException: Uncategorized exception occured during JMS processing; nested exception is javax.jms.JMSException: Error while attempting to add new Connection to the pool; nested exception is javax.jms.JMSException: Could not connect to broker URL: tcp://localhost:61616. Reason: java.net.ConnectException: Connection refused. Processed by failure processor: FatalFallbackErrorHandler[Channel[Wrap[com.cisco.ccbu.tempesta.failover.ClusterStatusPublisher$StatusPublishRoute$1@78a5c7] -> com.cisco.ccbu.tempesta.failover.ClusterStatusPublisher$StatusPublishRoute$1@78a5c7]]
... 59 more
2015-02-23 22:57:28,709 - INFO [Camel (camel-4) thread #9 - timer://tempesta-jms-timer:MarkerIgnoringBase@159] - ledConnectionFactory$1.makeObject(PooledConnectionFactory.java:111)
... 62 more
at org.apache.activemq.transport.tcp.TcpTransport.connect(TcpTransport.java:484)
... 69 more
2015-02-23 22:57:28,710 - INFO [Camel (camel-4) thread #9 - timer://tempesta-jms-timer:MarkerIgnoringBase@134] - 0000000171: 172.16.6.198: Feb 23 2015 22:57:28.709 +0530: %__TIMERCONSUMER-4-org.apache.camel.component.timer.TimerConsumer: Error processing exchange. Exchange[Message: {"componentStateSet":[{"compType":"bridge","state":"disconnected","count":1},{"compType":"zookeeper","state":"disconnected","count":1},{"compType":"activemq","state":"disconnected","count":1}],"msgType":"heartbeat","msgVirtualTimeStamp":1424709905748,"clusterNodeName":"A","clusterState":"OUT-OF-SERVICE"}]. Caused by: [org.springframework.jms.UncategorizedJmsException - Uncategorized exception occured during JMS processing; nested exception is javax.jms.JMSException: Error while attempting to add new Connection to the pool; nested exception is javax.jms.JMSException: Could not connect to broker URL: tcp://localhost:61616. Reason: java.net.ConnectException: Connection refused]
07-29-2015 01:16 AM
I want to ask a question.The livedata user is defined in CUIC or need to create it?If it need to be created in CUIC,how to do it?
Thanks a lot.
07-29-2015 02:02 AM
If we have defined Agent as supervisor in ICM,you will have an access into the live Data.
Please use Supervisor domain credentials to loginto CUIC.
sethu
07-30-2015 12:32 AM
Hi,sethu
Thanks for reply.
Is the "livedata" user a supervisor which displayed in 2.jpg?
And I want to know where do you find the topic schema URL that configure in JMS data resource.
All the documents show the URL like this
"http://11.111.11.111:8088/schema/rest/reportdefinition/schema/"
07-30-2015 07:38 AM
Here is an example of our environment. Maybe it will help.....
broker url:
failover:(tcp://localhost:61616,tcp://<yourpubip>:61616,tcp://<yoursubip>:61616)?jms.prefetchPolicy.all=25
topic schema with: https://localhost:12005/livedata/livedataSchema.xml
Also, probably doesn't make a difference, but we are using the actual ip's instead of hostnames. I think we had issues when using the hostname.
07-30-2015 07:50 AM
thanks for reply.
i want to know which username/password should i fill in the topic schema username /password?
Is it a user defined in system or i need to create it by myself
Thanks.
07-30-2015 10:05 AM
I believe you create it yourself. I cannot see anywhere in our current environment where the username livedata (this is the username we have in the data source) is referenced. Can you please attach your finesse xml as well. Just interested to see it.
Also, do the live reports even run in cuic?
08-04-2015 01:01 AM
08-06-2015 11:12 AM
So from my understanding.... its created by the system. You provide the Topic schema url and save the data source. I believe it gets populated automatically. Not 100% sure on that, but the credentials are created by the system.
try it once and let me know.
Also, attach the xml from the desktop layout you are using.
07-29-2015 08:45 AM
Did you edit your gadget in finesse admin and add in the hostname of the CUIC server?
