02-23-2015 12:52 PM - edited 03-07-2019 10:48 PM
do you think the Cisco 1801 router can handle a speed of 16Mbps down as only seeing around 6Mbps while testing speed test. I have seen that MTU size might help. Do you have any related recommendation or tips on how / if possible to improve internet speed ?
Let me know if I can check anything to improve this - or maybe if a direct connection to an external DSL modem would solve this issue.
02-23-2015 04:47 PM
Post the complete output to the command "sh dsl atm".
02-23-2015 09:42 PM
02-23-2015 11:42 PM
Output is good. No line errors.
1801 router can handle speed of up to 17.5 Mbps upload/download traffic (no encryption).
When you are doing the speed test was this done during the day, peak times, night times?
Can you post the output to the command "sh interface dial0"?
03-03-2015 08:18 PM
Thank You Leo - let me know if you/anyone notice anything for the below:
(btw test speeds do not go over the 6Mbps download (day or night) while ADSL line should be at least double this download speed)
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address is xxxxxxxxxxxxx
MTU 1492 bytes, BW 56 Kbit, DLY 20000 usec,
reliability 255/255, txload 13/255, rxload 1/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Interface is bound to Vi1
Last input never, output never, output hang never
Last clearing of "show interface" counters 6d15h
Input queue: 0/75/15/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
5 minute output rate 3000 bits/sec, 0 packets/sec
13713069 packets input, 2681963957 bytes
9481066 packets output, 1081265925 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1492 bytes, BW 612 Kbit, DLY 20000 usec,
reliability 255/255, txload 4/255, rxload 4/255
Encapsulation PPP, LCP Open
Listen: CDPCP
Open: IPCP
PPPoE vaccess, cloned from Dialer1
Vaccess status 0x44, loopback not set
DTR is pulsed for 5 seconds on reset
Interface is bound to Di1 (Encapsulation PPP)
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10000 bits/sec, 14 packets/sec
5 minute output rate 11000 bits/sec, 13 packets/sec
13713311 packets input, 2682029659 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9481298 packets output, 1081290311 bytes, 0 underruns
0 carrier transitions
03-03-2015 09:08 PM
Ain't going to help because the counters were cleared 6 days ago.
The current output shows no congestion and shows no output drops. Based on this output, I see no evidence the router is having problems.
