Cisco-Prime2.2
thusharadennis
Dear team,
we are using cisco prime 2.2 and we have one RAID  disk failure and we have replaced with the new disk .
After that also it is reflecting as red green led status.even the disk space also showing as same before(83..gb)
suggest what is the issue on this.????
TD
Sankar Aniyan
Curious to know if you got this fixed ??
Sankar
hi Sankar,
We have replaced the faulty disk with new one.After that i took two days for the new hard disk to synchronize.
TD
ramkris2
Can you get a screenshot from the Administration > Appliance page in the GUI ?
The disk space won't change. The physical appliance would continue to have 4 x 300 GB drives in RAID-5 configuration.
