02-23-2015 11:54 PM
Now i want to compare my ESA C-360 with ESA C380 and ESA C680 for planning replace new model but I cannot find out hardware of C360 following as below
- CPU/Memory/Disk Space
- RAID Mirroring
- Redundant Power Supply / Hot-Swappable Hard Disk
- Ethernet Interfaces / Speed / 10 Gigabit Ethernet Fiber Option
- Deployment of ESA C360 ( Small to medium business / medium-sized enterprise / Large Enterprise)
If who have this infomation please give or share this information to me.
PRAPAN-
Solved! Go to Solution.
02-24-2015 05:15 AM
Here are the old specs for the C360:
Model | C360 |
Platform | PE2950rev3 |
CPU / Count | 1x4 |
Type/Speed | Xeon 2.33.G |
Memory | 4GB |
Hard Disk Count | 2 |
Size | 300GB |
Network | 3 |
Devices | bce0, bce0, bce1 |
Fiber Option | No |
First Released | 6.3.5 |
RAID Level | 1 |
RAID Controller | 35GB |
Queue Size | 220GB |
Log Size | 12GB |
"DB" Size | 33,300 hours |
MTBF | 78,800 hours |
Fan Exhaust Volume | 43.5cfm |
Ambient Noise | 68.9db |
System Heat/Power (watts) | 260.4 |
Total Current (amps) | 1.25 |
Air Temp Rise (F) | 19.3 |
Weight (lbs): | 49 |
Since the appliance is EoL, we do not have it published any longer, that I am aware of.
The new hardware can be found:
http://www.cisco.com/c/en/us/products/security/email-security-appliance/models-comparison.html
02-24-2015 05:15 AM
Model | C360 |
CPU / Count | 1x4 |
Memory | 4GB |
Size | 300GB |
Network | 3 |
Fiber Option | No |
RAID Level | 1 |
Log Size | 12GB |
02-24-2015 06:22 PM
Hi Robert,
Thank you very much for your information. I would like to know, how to long end of life of C380 , C680 and C600v ? now I saw as "none announced end of life" which i'm not sure and the esav(C600v), Can it extend memory in the future ? Please suggest again.
PRAPAN-
02-24-2015 07:47 PM
Hey Prapan,
Details with regards to EOL of the newer platform (x80) hardware as they're new, there are no plans to push EOL dates as of yet, however that URL will be updated with more information should our product team decide to push out EOL dates.
Given it's a new hardware, I do not expect any EOL dates announced for quite a while at this point.
With regards to C600V memory capacity is 8GB by default and you can allocate more memory (RAM) towards the install should your hardware it's deployed on allow further memory allocation to the vESA. (From memory).
Matthew
02-27-2015 02:30 AM
Hi Matthew,
PRAPAN-
