02-25-2015 03:43 AM - edited 07-05-2021 02:36 AM
I have Linksys spa2102 (phone adapter with router), and the quastion is how to use remote control.
I know that in wan settings I have to enable "Remote Management" and port, I also choose static ip and wrote it in fields.
As I understand "Remote Management" function allows me to connect to linksys remotely from other place, from other internet.
So, now I know ip and port of linksys, but how to connect? Have I done all preparation for this?
Thank you
03-19-2015 11:44 AM
05-28-2015 02:49 AM
You need to enable the remote management in your case WAN Web Server of linksys SPA2102 and then to mention the port, by default it is port 80, you may use another not is used port as well, after configuring this.
you need to put you WAN public IP in address bar along with port which you define.
https://WAN_Public_IP:8080
