Smart Install Vstack Possible DHCP Issues
andrewnabors
I am trying to get smart install to work with a 3750-X 15.2(3)E as the director, local DHCP but still able to access a network based TFTP server.
I am at the point where I can see the switches under 'sh vstack status' however the upgrade/config will never initiate automatically.  With the debugging that I have done, I am assuming there is something not right with DHCP to tell the client what to do.
Director Config:
vstack-director#sh vstack config
 Role: Director (SmartInstall enabled)
 Vstack Director IP address: 10.1.196.254
 Vstack Mode: Basic
 Vstack default management vlan: 1
 Vstack start-up management vlan: 5
 Vstack management Vlans: 5
 Vstack Config file: tftp://10.1.18.50/2960x_48p_base.txt
 Join Window Details:
         Window: Open (default)
         Operation Mode: auto (default)
 Vstack Backup Details:
         Mode: On (default)
         Repository: flash:/vstack (default)
ip dhcp remember
ip dhcp conflict resolution
ip dhcp excluded-address 10.1.204.0 10.1.206.254
ip dhcp snooping vlan 1,4-5
ip dhcp snooping
All access Interface configs
interface GigabitEthernet1/0/1
 switchport access vlan 5
 switchport mode access
 ip arp inspection trust
 load-interval 30
 spanning-tree portfast
 ip dhcp snooping trust
interface Vlan1
 ip address 10.1.196.254 255.255.252.0
 no ip route-cache
ip default-gateway 10.1.196.1
ip forward-protocol nd
no ip http server
ip http secure-server
tftp-server flash:client_cfg.txt
vstack vlan 5
vstack config tftp://10.1.18.50/2960x_48p_base.txt
vstack group built-in 2960x 48-2sfp-poe
 image tftp://10.1.18.50/c2960x-universalk9-tar.152-3.E.tar
vstack group built-in 3560cg 8-pd-poe
 image tftp://10.1.18.50/c3560-ipbasek9-tar.150-2.SE7.tar
vstack dhcp-localserver pool1
 address-pool 10.1.204.0 255.255.252.0
 file-server 10.1.18.50
 default-router 10.1.204.1
vstack director 10.1.196.254
vstack basic
vstack startup-vlan 5
vstack-director#ping 10.1.18.50
Sending 5, 100-byte ICMP Echos to 10.1.18.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
Client #1 Info:
WS-2960X-48LPD-L -- 15.2(3)E
*Mar  1 00:00:29.492: Read env variable - LICENSE_BOOT_LEVEL =
Mar 30 01:27:38.153: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Feb 25 18:31:24.090:  in Switch 0. Cannot read pid from Flexstack module
Feb 25 18:32:14.398: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
Feb 25 18:32:15.722: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Feb 25 18:32:15.722: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Feb 25 18:32:18.057: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Feb 25 18:32:40.871: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Feb 25 18:32:40.871: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Feb 25 18:32:40.871: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Feb 25 18:32:42.758: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Feb 25 18:32:43.244: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(3)E, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 07-Dec-14 12:57 by prod_rel_team
Feb 25 18:32:44.691: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
Feb 25 18:32:45.694: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Feb 25 18:32:45.837: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Feb 25 18:32:48.099: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Feb 25 18:32:49.102: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Feb 25 18:32:57.760: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to down
Feb 25 18:32:57.798: %SYS-5-CONFIG_I: Configured from console by tty17
Feb 25 18:33:27.798: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to up
Feb 25 18:33:32.810: DHCP: No configured hostname - not including Hostname option
Feb 25 18:33:35.994: %DHCP-6-ADDRESS_ASSIGN: Interface Vlan5 assigned DHCP address 10.1.206.255, mask 255.255.252.0, hostname
 got vend id vend spec. info ret: succeed
Feb 25 18:34:11.737: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server https://devicehelper.cisco.com/pnp/HELLO
Feb 25 18:34:49.783: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server https://devicehelper.cisco.com/pnp/HELLO got vend id vend spec. info ret: succeed
I can't get anything past this point.
vstack-director#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
10.1.206.255    0063.6973.636f.2d33.    Mar 31 2011 01:32 AM    Remembered Terminated Vlan1
                3831.632e.3161.3536.
                2e62.6334.312d.566c.
                35
vstack-director#sh vstack status
SmartInstall:  ENABLED
Status: Device_type Health_status Join-window_status Upgrade_status
Device_type:  S - Smart install N - Non smart install P - Pending
Health_status:  A - Active I - Inactive
Join-window_Status:  a - Allowed  h - On-hold   d - Denied
Image Upgrade:   i - in progress     I - done           X - failed
Config Upgrade:  c - in progress     C - done           x - failed
Script Upgrade:  p - in progress     P - done           F - failed
Director Database:
DevNo  MAC Address     Product-ID         IP_addr          Hostname    Status
0      d072.dced.1d80  WS-C3750X-12S      10.1.196.254     vstack-dir  Director
1      381c.1a56.bc00  WS-C2960X-48LPD-L  10.1.206.255     Switch      S A a
2      b8be.bfc4.4800  WS-C2960S-48LPS-L  10.1.196.111     GigAccess.  S A a
Device Num     : 1
Device ID      : Switch
MAC Address    : 381c.1a56.bc00
IP Addr        : 10.1.206.255
Hop value      : 1
Serial         : Not Found
Hw Version     : Not Found
Product-ID     : WS-C2960X-48LPD-L
Supervisor     : Not Applicable
Version        : 15.2(3)E
Image          : C2960X-UNIVERSALK9-M
Entry Role     : IBC Entry
(N-1)HOP Entry : d072.dced.1d80
Backup done    :  no
Latest backup file: none
Latest backup client name: none
File checksum     : none
Switch replace type: New switch
SMI Version     : 0
Status            : S A a
Capability     : Network derived SMI management VLAN supported
vstack-director#sh vstack download-status
Total no of entries : 1
No   client-IP        client-MAC      Method          Image-status    Config-status    Script-status
1    10.1.206.255     381c.1a56.bc00  zero-touch      NOT STARTED        NOT STARTED     NOT STARTED
So my question is - why won't the zero-touch process initiate?
7 Replies 7
Leo Laohoo
I know why the IOS upgrade won't happen.  This will depend entirely on the IOS code running in your 3750.  With later codes, starting from 15.0(2)SE, the developers allowed the vstack to "think".  If the slave switch has exactly the same IOS as what's specified in the commands, then the process of upgrading the switch is skipped.  Older versions, like 12.2(55)SE3 and later, will upgrade the IOS regardless.   As a matter of fact, the IOS loaded in the 3750X has been refined.  With older 15.0(2)SE,  the "skipping" only happens halfway through the IOS upgrade.  If I remembered correctly, 15.2(3)E is a lot smoother that it will skip completely and s(h)aves about 3 minutes.
In regards to the config, can you ensure the 2960X does NOT have any configuration file and VLAN.dat file?
Thank you for the reply Leo.  In regards to not updating the IOS, I did read the same thing.  I am still curious why it would not update the vstack status to reflect that.  Also, it does not update the config.  Right now, the config txt file is just setting the hostname to something different.
Although the process does not start automatically, I can run the commands to do it manually.
vstack-director#$load-config built-in 2960x 48-2sfp-poe NONE startup
Startup config of Clients will be replaced. proceed?[confirm]
vstack-director#
Feb 25 20:48:16.121: %SMI-6-UPGRD_STARTED: Device (IP address: 10.1.206.255) startup-config upgrade has started
Feb 25 20:18:02.796: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server https://devicehelper.cisco.com/pnp/HELLO got vend id vend spec. info ret: succeed
Loading 2960x_48p_base.txt from 10.1.18.50 (via Vlan5): !
[OK - 20 bytes]
Feb 25 20:47:27.567: %SMI-6-UPGRD_STARTED: Device (IP address: 10.1.206.255) startup-config upgrade has started
Feb 25 20:47:36.920: %SYS-5-CONFIG_NV_I: Nonvolatile storage configured from tftp://10.1.18.50/2960x_48p_base.txt by console
Feb 25 20:47:38.074: %SMI-6-UPGRD_SUCCESS: Device (IP address: 10.1.206.255) startup-config has upgraded successfully
Director Database:
1      381c.1a56.bc00  WS-C2960X-48LPD-L  10.1.206.255     Switch      S A a  C
Regarding the vlan.dat file - When I reset I am sure to remove that file as well.  You may notice some stuff about vlan5.  I am using vlan5 because this is an open vlan in our network and the goal of this process is for another system to be able to access these switches.  My vstack config should show the 'vstack startup-vlan' as vlan 5 - which it is setting.   If I 'return' on the client switch and do a 'sh int status' I am able to see the director successfully updated the vlan to vlan5 on the client switch.
vstack vlan 5
I've compared your VStack configuration against my production VStack switch and they are identical (except for the IP Address and the model of your switch).
The only thing that caught my eye, and I"m not sure if this is a type-o in your part, is the second line above.  It doesn't make sense and could be a bug.  I am suspecting you cannot just remove that offending line so you'll need to take the entire VStack configuration off and enter it back again but without the line there.
Sorry, what I meant was make sure sure the 2960X doesn't contain any config.text or VLAN.dat file.  The only file that should be in the 2960X is the IOS (and two other associated files) and nothing else.
The 'vstack config ...' line is there from testing I was trying to do - originally thinking something was wrong with my vstack group configuration, this should have applied that config to all switches.  Here is the last half of show run with that removed now.
interface Vlan1
 no ip route-cache
no ip http server
vstack vlan 5
vstack basic
Here is a flash directory listing of the switch (yes, it does get to the standard out of box screen when I hit my first return)
Switch#
Switch#dir flash:
Directory of flash:/
  672  -rwx        1048  Feb 26 2015 15:46:22 +00:00  multiple-fs
    3  drwx         512  Feb 24 2015 22:44:22 +00:00  c2960x-universalk9-mz.152-3.E
  670  drwx         512  Feb 24 2015 22:44:24 +00:00  dc_profile_dir
122185728 bytes total (92985856 bytes free)
Switch#
I also cleared out the director DB since I had forced the config update:
Director Database:
vstack-director#
Press RETURN to get started!
*Mar  1 00:00:29.391: Read env variable - LICENSE_BOOT_LEVEL =
Feb 26 16:18:52.090:  in Switch 0. Cannot read pid from Flexstack module
Feb 26 16:19:42.391: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the st        ack
Feb 26 16:19:43.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, chan        ged state to down
Feb 26 16:19:43.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne        t0, changed state to down
Feb 26 16:19:46.043: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type        vlan
Feb 26 16:20:08.846: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Feb 26 16:20:08.846: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has ch        anged to state DOWN
Feb 26 16:20:08.846: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has ch        anged to state DOWN
Feb 26 16:20:10.737: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Feb 26 16:20:11.223: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(3)E, RE        LEASE SOFTWARE (fc4)
Feb 26 16:20:12.670: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to d        own
Feb 26 16:20:13.670: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne        t0, changed state to down
Feb 26 16:20:13.834: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Feb 26 16:20:16.067: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed sta        te to up
Feb 26 16:20:17.070: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe        rnet1/0/1, changed state to up
Feb 26 16:20:25.774: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, chan        ged state to down
Feb 26 16:20:25.812: %SYS-5-CONFIG_I: Configured from console by tty17
Feb 26 16:20:55.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to up
Feb 26 16:21:00.821: DHCP: No configured hostname - not including Hostname option
Feb 26 16:21:07.975: %DHCP-6-ADDRESS_ASSIGN: Interface Vlan5 assigned DHCP address 10.1.206.255, mask 255.255.252.0, hostname
Feb 26 16:21:39.723: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server https://devicehelper.cisco.com/pnp/HELLO
Feb 26 16:22:17.769: %PNP-6-HTTP_CONNECTING: PnP Discovery trying to connect to PnP server https://devicehelper.cisco.com/pnp/HELLO
Based on that, the zero-touch install is not starting.  Leading me back to like a DHCP issue - but not sure what since my config looks fine.  I have also tested on a 4500X as a director with no luck.
Wait a minute ... Why is the 2960X getting the correct time and date?
Can you try loading an OLD version of an IOS to the 2960X and try again.
Reboot the VStack director too.
Another thing ... Your IP address, can you confirm the subnet you're using is NOT routed or being used anywhere else?
Hi Leo,
I wanted to update you with the good news, I got it working!  After going through things again here are the changes I made:
  • Add interface Vlan5 to the director switch with an IP in the subnet (10.1.204.2)
  • Removed the ip-helper on vlan 5 (on the core) pointing back to the director - this is to help keep all the trafic local.
  • Change the vstack director from 10.1.196.254 (vlan 1 int ip addr) to 10.1.204.2 (vlan 5 address)
If you have any other questions feel free to ask.
Ok, I totally missed that.
Good of you to find out where it went wrong!
