02-25-2015 05:41 PM - edited 03-07-2019 10:51 PM
Does anyone know if the CWDM optics are supported on the 3850-12S or 3850-24S switches (i.e. 12 or 24 SFP ports) - on the fixed SFP ports? On the SFP compatibility matrix it only lists compatibility for the C3850-NM-4-1G module. It looks like the compatibility matrix is not up to date as it doesn't even list compatibility for the 12S or 24S switches even for standard SX SFP's...
Cheers
02-25-2015 06:17 PM
Go HERE. According to the document CWDM is supported on the C3850-NM-4-1G only.
02-25-2015 06:21 PM
Hi Leo
I have checked the document - it doesn't list any compatibility for the 12S or 24S switches, so I don't believe it is current (otherwise nothing would be compatible with these switches)
Cheers
02-25-2015 06:30 PM
Then go HERE and look at Table 10. This one is a lot more vague because it doesn't mention whether CWDM/DWDM will work on the appliance or on the network module.
If in doubt, either raise a TAC Case or contact your authorized Cisco reseller or your Cisco AM/SE and have the response in writing.
02-25-2015 06:35 PM
Hi Leo
Thanks again... unfortunately I agree, the data sheet isn't very specific.
Has anyone actually used / tested the CWDM optics on the 3850 12S or 24S switches?
Cheers
03-05-2015 12:32 PM
I logged a TAC case a few days ago, they have confirmed support for the CWDM optics and the compatibility matrix page has now been updated
Cheers
03-05-2015 01:43 PM
Thanks for taking the time to provide everyone else the feedback and update. :)
