02-26-2015 07:55 AM - edited 03-18-2019 04:06 AM
hi guys,
I can't find any information regarding calling SIP endpoints outside of the organization.
for example I've found some person, there is sip address - someone@acme.com by which I can reach him. I want call him from endpoint registered at VCS infrastructure. something close to it is in this document (on page 28) but there are no exact confirmation about my suggestion.
is it possible at all? and what I need to deploy that?
thanks!
Solved! Go to Solution.
02-27-2015 01:23 AM
Create the search rule as per the documentation - that's all you have to do. To confirm that it is working properly, you can test it with the Cisco loopback service which will loop your own video back to you; dial loopback@rtp.ciscotac.net
To dial someone@acme.com you do not have to do anything at all, however, the people/organisation you are calling must have the appropriate SRV records in place - same for you, if you want people to call you using alias@domain, then you must have the appropriate SRV records in place.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
02-26-2015 10:03 AM
That is the correct documentation you are looking at, where are you stuck as far as implementation goes?
02-27-2015 01:26 AM
I'm just in the planning phase because you know with VCS licenses you need to be very careful.
btw, you may notice I'm newbie with TelePresence:)
thanks for your advice
02-27-2015 01:23 AM
/jens
02-27-2015 01:23 AM
I suppose appropriate DNS records described on page 49 in the mentioned document?
thanks for the clarification
02-27-2015 02:01 AM
That is correct.
/jens
02-27-2015 02:07 AM
thanks
