02-26-2015 10:27 AM - edited 03-17-2019 02:08 AM
Is it possible in Call manager 10.5 to forward calls that are received from a certain extension but allow all other calls to be received as normal or to block calls that are transferred to a certain extension to another extension.
02-26-2015 10:40 AM
This is all we have:
What you're looking is the concept of white/black lists which is not something CUCM has.
About transfers, no such thing either, the same CSS you use to place any calls is the one you use for transfers.
02-26-2015 11:47 PM
Could you (ab)use supportforums.cisco.com/docs/DOC-18367 or CURRI to achieve some of this?
GTG
