02-26-2015 07:02 PM - edited 03-19-2019 09:15 AM
I am planning a solution for the CallManager publisher resilience. Actually, I want to deploy two publishers: One is for the main site and second is for the backup site (Active/Standby). Is it the vMotion support that? Not support on CallManager util now?
02-26-2015 07:33 PM
Review this:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#VMware_vMotion
NOTE: support varies by app and version. Before reading the best practices below, verify support at Supported Editions and Features of VMware vSphere ESXi, VMware vCenter and VMware vSphere Client.
This feature migrates a live, running Virtual Machine (VM) from one physical server to another.
The following applies to any use of vMotion with UC apps:
If the UC app is listed as "Supported with Caveats", then support is as described below:
If the UC app is listed as "Partial" support, then support is “maintenance mode only” as described below:
Ref: http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Supported_Features_of_VMware_vSphere_ESXi.2C_VMware_vCenter_and_VMware_vSphere_Client
Feature | CUCM PCD PLM | Cisco Paging Server | CER | SME | CUxAC | PCP | PCA | UPM | UOM, USM, USSM | CIME | Unity Connection | CUP + IM&P |
vSphere ESXi 4.0 Features | ||||||||||||
VM Templates (OVAs) | Y(C) | Y(C) | Y(C) | Y(C) | Y | Y | Y | Y | Y(C) | Y(C) | Y(C) | |
Copy Virtual Machine | Y(C) | Y(C) | Y(C) | No | Y(C) | no | Y(C) | No | Y(C) | Y(C) | Y(C) | |
Restart Virtual Machine on Different ESXi Host | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | Y(C) | |
Resize Virtual Machine | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | Y(P) | |
VMware Hot Add | No | No | No | No | No | No | No | No | No | No | No | |
Multiple Physical NICs and vNICs | Y(P) | Y(P) | Y(P) | Y(P) | Yes | Y(P) | Yes | Y(P) | Y(P) | Y(P) | Y(P) | |
VMware High Availability (HA) | Y(C) | Y(C) | Y(C) | No | Y(C) | No | Y(C) | No | Y(C) | Y(C) | Y(C) | |
VMware Site Recovery Manager (SRM) | Y(C) | Y(C) | Y(C) | No | Y(C) | No | Y(C) | No | Y(C) | Y(C) | Y(C) | |
VMware vNetwork Distributed Switch | Y(C) | Y(C) | Y(C) | No | Y(C) | No | Y(C) | No | Y(C) | Y(C) | Y(C) | |
VMware vMotion | Y(C) | Y(C) | Y(C) | Y(P) | Yes | No | Yes | No | No | Y(P) | Y(C) | |
VMware Dynamic Resource Scheduler (DRS) | No | No | No | No | No | No | No | No | No | No | No | |
VMware Dynamic Power Management | No | No | No | No | No | No | No | No | No | No | No | |
Long Distance vMotion | No | No | No | No | Y(C) | No | Y(C) | No | No | No | No | |
VMware Storage vMotion | Y(C) | Y(C) | No | No | Yes | No | Yes | No | No | No | No |
New vSphere ESXi 5.x Features | ||||||||||||
vSphere Storage Appliance | See Storage Requirements for Specs-based hardware support (click here) | |||||||||||
vSphere Data Protection (VDP) | No | No | No | No | No | No | No | No | No | No | No | No |
All other new features in vSphere ESXi 5.x | No | No | No | No | No | No | No | No | No | No | No | No |
-Terry
01-18-2017 05:48 AM
Not support the Long Distance vMotion is fine. But why need the same of storage? Layer 2?
Can I use the different local storage to make the Live vMotion?
01-18-2017 05:58 AM
Officially not supported, though I have done it many times. Depending on ESXi version you may need to use the web client (plenty info out there on google).
Otherwise you would need to shut down the VM and then perform vMotion.
01-18-2017 08:25 PM
Officially not supported, though I have done it many times. <---- On your experience, that is no down time to make the Live vMotion without shared storage?? Fine??
02-01-2019 01:15 AM
i need to migrate ccm pub into different dc. I know vmotion is not possible due to no support on long distance. What are the other possible ways to migrate and sync with subs.
Any impact on licensing?
Regads,
02-01-2019 06:50 AM
You can re-IP the Pub (Cisco has a doc with steps for each CUCM version) and then SCP copy the VM to new ESXi host.
01-19-2017 03:40 AM
Hi Chi,
Prior to ESXi 5.1, VM must be installed on shared storage (SAN) and source and destination physical servers must be connected to same SAN. In ESXi 5.1+ vMotion allows "DAS to DAS", i.e. VM can be installed on DAS and source/destination physical servers can have different DAS yet still vMotion the VM.
Manish
