02-27-2015 04:21 AM - edited 03-17-2019 02:08 AM
CUCM 10.5, MGCP VGW with E1s
Required to make a group of users to make external calls with the same external number. i.e. the shown Calling number at the second end will be the same, whomever the user made the call of this group.
Regards.
Solved! Go to Solution.
02-27-2015 05:44 AM
Set it either as External phone number mask on the phone, route pattern, route group or look into using calling party transformation and apply to the GW (don't recall if MGCP allows you to apply transformation patterns).
02-27-2015 05:43 AM
Not sure I understand you here but I will give it a whirl. Just set the External Phone Number Mask option to whatever number you want to appear on the called party's phone (the ANI). I think that is what you are asking for? This is found in the line setting per phone.
02-27-2015 06:38 AM
Hi Brandon,
I tried that part of External Phone Mask at the Line page, but it didn't work. the call ANI still go with the DID. but it is required to use another number.
02-27-2015 06:51 AM
Don't use translation use transformation pattern.
03-03-2015 03:27 AM
Hello Chris,
Applying Calling Party Mask at the Route Pattern worked correctly.
Thanks for your support.
02-27-2015 05:44 AM
02-27-2015 06:46 AM
I spent a lot of time to do it using the translation pattern, and of course it didn't work. The Route Pattern sounds to be more correct. I will create new route pattern for this group of users only and apply the external phone number under it.
Regards.
