02-27-2015 07:17 AM - edited 02-21-2020 08:06 PM
Hi All,
I have been struggling for some days and really need some help here. My PC (192.168.254.x) is on the same vlan with outside interface (192.168.254.171) of my PIX506E. When I launch the Cisco VPN client, my PC shows connected and gets the IP of 10.9.0.150 which is expected. However, it also gets the gateway of 10.9.0.1 which I have no idea where it comes from. Thus my PC can't access any internal network or external network.
I've listed my configuration below and highlighted the part that I typed in. PIX version 7.1(2) is the highest version I can install on PIX506E. Please help. Thanks a lot.
pixfirewall# sh run
: Saved
PIX Version 7.1(2)
hostname pixfirewall
enable password 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 192.168.254.171 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
passwd 2KFQnbNIdI.2KYOU encrypted
boot system flash:/pix712.bin
ftp mode passive
pager lines 24
logging enable
logging timestamp
logging buffered informational
mtu outside 1500
mtu inside 1500
ip local pool ROBERT-POOL 10.9.0.150-10.9.0.160 mask 255.255.255.0
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.254.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy Robert-GP internal
group-policy Robert-GP attributes
dns-server value 8.8.8.8
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
username robert password yXUoa8oHzS0Ncp2O encrypted
username robert attributes
vpn-group-policy Robert-GP
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set MYSET esp-3des esp-md5-hmac
crypto dynamic-map DYN1 1 set transform-set MYSET
crypto dynamic-map DYN1 1 set reverse-route
crypto map MYMAP 1 ipsec-isakmp dynamic DYN1
crypto map MYMAP interface outside
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash sha
isakmp policy 1 group 2
isakmp policy 1 lifetime 43200
isakmp nat-traversal 30
tunnel-group ROBERT-GROUP type ipsec-ra
tunnel-group ROBERT-GROUP general-attributes
address-pool ROBERT-POOL
default-group-policy Robert-GP
tunnel-group ROBERT-GROUP ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
ssh version 2
console timeout 0
ssl encryption rc4-md5
Cryptochecksum:7157c6095f2abae2aae9e15c1caa81aa
: end
pixfirewall#
Solved! Go to Solution.
03-01-2015 08:26 PM
did you disconnect from the vpn session after adding the new ACL to outside interface and try it again ?
disconnect from vpn session and try again and if does not work apply this line.
same-security-traffic permit intra-interface
show crytop ipsec sa.
Please post this output.
thanks
02-27-2015 09:14 AM
Hi Robert,
You are missing nat exemption.
Copy these two lines, will fix your problem.
access-list nat0 extended permit ip 10.10.10.0 255.255.255.0 10.9.0.0 255.255.255.0
nat (inside) 0 access-list nat0
Rizwan Rafeek
02-27-2015 12:22 PM
Thank you Rizwan for your reply.
I added the nat statement but still got the same result. Please see the ifconfig/all output of my PC below.
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Cisco Systems VPN Adapter for 64-bit Windows
Physical Address. . . . . . . . . : 00-05-9A-3C-78-00
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::919c:fda:e42e:f9b9%24(Preferred)
IPv4 Address. . . . . . . . . . . : 10.9.0.150(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.9.0.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
NetBIOS over Tcpip. . . . . . . . : Enabled
02-27-2015 12:44 PM
Are you able to ping inside the network ?
02-27-2015 03:13 PM
No, I'm not.
The only IP I can ping is the outside interface of the PIX 192.168.254.171. I cann't ping the inside interface 10.10.10.1.
02-27-2015 03:42 PM
Ok, please remove this line.
no crypto dynamic-map DYN1 1 set reverse-route
and try it let me know.
thanks
02-27-2015 04:11 PM
Removed "crypto dynamic-map DYN1 1 set reverse-route". Still got the same thing. My PC keeps getting the default gateway of 10.9.0.1. It's driving me nuts. Where does it come from?
I've attached the latest running-config, screenshots of Cisco VPN client and ipconfig of my pc.
02-27-2015 04:33 PM
I wouldn't worry too much about the default-gateway address, it may well be due to old version setup style but it is still does not answer the question, why you couldn't access inside the network.
I notice, there is missing global policy on your firewall.
Below is default inspect policy is found Cisco firewall, which I don't see it on your Firewall configuration?
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
inspect icmp
service-policy global_policy global
02-28-2015 08:10 AM
Rizwan, Thank you again for your reply.
I don't know why that global policy is missing. I've added them and still I can't ping inside interface or default gateway. I can only ping outside interface.
I've attached the latest show ver and show run. I am wondering if you can remote ssh to my PIX to take a look and also try easy VPN from your end. I can give your full access. Thank you very much!
Robert Huang
02-28-2015 12:18 PM
Ping you ping a host IP address inside the network (not the inside interface itself), a host IP address instead?
When you established a remote-in vpn session with your PIX, please issue show command and post your the show output.
show crypto is isakmp sa
show crypto ipsec sa
02-28-2015 05:26 PM
Once my VPN gets connected,
1.My PC 10.9.0.150 can't ping the internal IP of 10.10.10.10 and vice versa.
2.My Firewall can ping 10.9.0.150.
I've listed all the information below.
pixfirewall# sh ip
System IP Addresses:
Interface Name IP address Subnet mask Method
Ethernet0 outside 192.168.254.171 255.255.255.0 CONFIG
Ethernet1 inside 10.10.10.1 255.255.255.0 manual
Current IP Addresses:
pixfirewall# ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
pixfirewall#
pixfirewall# sh crypto isakmp sa
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 192.168.254.111
Type : user Role : responder
Rekey : no State : AM_ACTIVE
pixfirewall#
pixfirewall# sh crypto ipsec sa
interface: outside
Crypto map tag: DYN1, seq num: 1, local addr: 192.168.254.171
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (10.9.0.150/255.255.255.255/0/0)
current_peer: 192.168.254.111, username: robert
dynamic allocated peer ip: 10.9.0.150
#pkts encaps: 5, #pkts encrypt: 5, #pkts digest: 5
#pkts decaps: 74, #pkts decrypt: 74, #pkts verify: 74
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 5, #pkts comp failed: 0, #pkts decomp failed: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 192.168.254.171, remote crypto endpt.: 192.168.254.111
path mtu 1500, ipsec overhead 60, media mtu 1500
current outbound spi: E7BD277C
inbound esp sas:
spi: 0xAFA26657 (2946655831)
transform: esp-3des esp-md5-hmac
in use settings ={RA, Tunnel, }
slot: 0, conn_id: 1, crypto-map: DYN1
sa timing: remaining key lifetime (sec): 28548
IV size: 8 bytes
replay detection support: Y
outbound esp sas:
spi: 0xE7BD277C (3887933308)
sa timing: remaining key lifetime (sec): 28547
IV size: 8 bytes
pixfirewall# ping 10.9.0.150
Sending 5, 100-byte ICMP Echos to 10.9.0.150, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/20 ms
02-28-2015 07:09 PM
Check the device itself at 10.10.10.10, whether Windows firewall is enabled and make sure that device it has a proper gateway address is point back to firewall's inside address.
As far as your remote-access vpn is concerned I see traffic is flowing just fine.
Rizwan Rafeek
03-01-2015 08:17 AM
Hi Rizwan,
You're right. Device 10.10.10.10 has a wrong gateway. Once I set the gateway to 10.10.10.1, my VPN client (original IP 192.168.254.111, VPN IP 10.9.0.151) can successfully access the inside network 10.10.10.0/24.
However, my VPN client still cannot access any outside network. For instance, it cann't ping the firewall default gateway 192.168.254.1. I didn't capture any packet on the FW outside interface when 10.9.0.151 was trying to ping/telnet 192.168.254.1 and 8.8.8.8.
The main purpose I set up the easyVPN is to provide VPN service for my friends in other country which has a very strict Internet policy. The PPTP/L2TP/OpenVPN are blocked there. So they don't need to access my internal network, they do need access to all public websites like youtube, facebook.
I listed the routing table below when the easyVPN is established. Please help again. Thank you very much!
pixfirewall# sh route
S 0.0.0.0 0.0.0.0 [1/0] via 192.168.254.1, outside
S 10.9.0.151 255.255.255.255 [1/0] via 192.168.254.111, outside
C 10.10.10.0 255.255.255.0 is directly connected, inside
C 192.168.254.0 255.255.255.0 is directly connected, outside
pixfirewall#
03-01-2015 09:51 AM
If remote-in vpn-clients need access to Internet, then you just need this line.
global (outside) 1 interface
nat (outside) 1 10.9.0.0 255.255.255.0
If remote-in vpn-clients need access to subnets residing outside the your pix, then you would need a nat exemption like below.
access-list nat0-out extended permit ip 10.9.0.0 255.255.255.0 192.168.254.0 255.255.255.0
nat (outside) 0 access-list nat0-out outside
Hope that answers your question.
03-01-2015 02:13 PM
Hi Rizwan,
I followed your instruction but I still couldn't access both outside subnet and internet. See below.
pixfirewall# sh run access-list
pixfirewall#
pixfirewall# sh run nat
pixfirewall#
pixfirewall# sh run global
pixfirewall#
I got a warning when I typed in the nat statement.
pixfirewall(config)# nat (outside) 1 10.9.0.0 255.255.255.0
WARNING: Binding inside nat statement to outermost interface.
WARNING: Keyword "outside" is probably missing.
show log when VPN client 10.9.0.151 trying to ping 8.8.8.8
8:42:38: %PIX-5-713120: Group = ROBERT-GROUP, Username = robert, IP = 192.168.254.111, PHASE 2 COMPLETED (msgid=90e630f0)
Jan 07 1993 08:42:39: %PIX-6-305011: Built dynamic UDP translation from outside:10.9.0.151/137 to outside:192.168.254.171/9
Jan 07 1993 08:42:39: %PIX-3-305005: No translation group found for udp src outside:10.9.0.151/137 dst outside:10.9.0.255/137
Jan 07 1993 08:42:41: %PIX-6-110001: No route to 239.255.255.250 from 10.9.0.151
Jan 07 1993 08:42:46: %PIX-3-305005: No translation group found for udp src outside:10.9.0.151/137 dst outside:10.9.0.255/137
Jan 07 1993 08:42:47: %PIX-6-305011: Built dynamic UDP translation from outside:10.9.0.151/138 to outside:192.168.254.171/10
Jan 07 1993 08:42:47: %PIX-3-305005: No translation group found for udp src outside:10.9.0.151/138 dst outside:10.9.0.255/138
Jan 07 1993 08:42:47: %PIX-6-305011: Built dynamic ICMP translation from outside:10.9.0.151/1536 to outside:192.168.254.171/5
Jan 07 1993 08:42:47: %PIX-6-302021: Teardown ICMP connection for faddr 10.9.0.151/1536 gaddr 8.8.8.8/0 laddr 8.8.8.8/0
Jan 07 1993 08:42:52: %PIX-3-305005: No translation group found for udp src outside:10.9.0.151/138 dst outside:10.9.0.255/138
Jan 07 1993 08:42:52: %PIX-5-713050: Group = ROBERT-GROUP, Username = robert, IP = 192.168.254.111, Connection terminated for peer robert. Reason: Peer Terminate Remote Proxy 10.9.0.151, Local Proxy 0.0.0.0
Jan 07 1993 08:42:52: %PIX-4-113019: Group = ROBERT-GROUP, Username = robert, IP = 192.168.254.111, Session disconnected. Session Type: IPSec, Duration: 0h:00m:14s, Bytes xmt: 0, Bytes rcv: 2855, Reason: User Requested
Jan 07 1993 08:42:52: %PIX-6-602304: IPSEC: An inbound remote access SA (SPI= 0x8CF8662C) between 192.168.254.171 and 192.168.254.111 (user= robert) has been deleted.
Jan 07 1993 08:42:52: %PIX-6-602304: IPSEC: An outbound remote access SA (SPI= 0x1230E6AB) between 192.168.254.171 and 192.168.254.111 (user= robert) has been deleted.
Jan 07 1993 08:42:52: %PIX-5-713904: IP = 192.168.254.111, Received encrypted packet with no matching SA, dropping
Latest running-config is showing below.
pixfirewall# sh run
: Saved
PIX Version 7.1(2)
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
ftp mode passive
pager lines 24
logging enable
logging timestamp
mtu outside 1500
mtu inside 1500
arp timeout 14400
vpn-tunnel-protocol IPSec
pre-shared-key *
telnet timeout 5
ssh timeout 60
ssh version 2
console timeout 0
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
inspect icmp
Cryptochecksum:7351e447f85b5948361b649183a9c53d
: end
pixfirewall#
