03-03-2015 07:23 AM - edited 03-17-2019 02:11 AM
Hi Guys,
I tryind configuration voice mail in CUE, but, don´t working. I am doing the follow test:
I do external call to xxxx.5507 that is configurated call forward no answer and call forward busy. The DN is idle, and when the call try transfer to Pilot 5000, I receive the busy tone. The same problem occur when the user to do internal call.
Follow part configuration:
dial-peer voice 5000 voip
description description ***VOICE_MAIL_AUTO_ATENDIMENTO***
destination-pattern 500[0-5]
session protocol sipv2
session target ipv4:10.93.4.10
dtmf-relay sip-notify
codec g711ulaw
no vad
elephony-service
no auto-reg-ephone
max-ephones 58
max-dn 300
ip source-address 10.93.4.10 port 2000
timeouts interdigit 5
system message xxxxxx
url services http://10.93.4.10/voiceview/common/login.do
url authentication http://10.93.4.10/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7915-12 B015-1-0-4.SBN
load 7937 apps37sccp.1-4-5-7.bin
load 7942 SCCP42.9-3-1SR2-1S.loads
load 6921 SCCP69xx.9-2-4-3.loads
load 6901 SCCP6901.9-3-1-SR1-3.loads
voicemail 5000
max-conferences 8 gain -6
call-forward pattern .T
moh "music-on-hold.au"
web admin customer name admin password FlixMedia@2014
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
phone-dn 8 octo-line
number 5507
pickup-group 1
label Danilo Cardoso JOVEM
description 45675507
name Danilo Cardoso JOVEM
allow watch
call-forward busy 5000
call-forward noan 5000 timeout 20
corlist incoming CSS-DDI
mwi sip
Any have idea about this?
Wilson
03-03-2015 12:21 PM
Wilson,
What happens when you call 5000 from an internal phone? Have you configured the ccn trigger and sip subsystem within CUE?
FG
03-04-2015 04:44 AM
Hi Francisco,
Thank You for your contact. Now is working. We review again the configuration and found two erros:
The destination-pattern in dial-peer was configured to CME not CUE
In the CUE the pilot was created with another number.
Wilson
03-04-2015 05:56 AM
Great! Glad to hear.
