intermittent blank screen. please help.
chengsoon-tan
Hi everyone, i have an issue and can't seem to pinpoint what is the reason for the cause. I have recently relocated the cisco telepresence unit and now it is having intermittent screen just go blank and then reappear again. Checked physical cables, ip address, hardwares, almost everything, seems to be working fine. Has anyone encountered this before?
Martin Koch
Could you tell us a bit more, what kind of system are you talking about, there are
many Cisco TelePresence systems, is the screen integrated and from Cisco or is
it a third party screen.
When and how does the blackout occur. Like does it only happen in a call, is it the
complete content of the screen which is off, ...
Often it can be helpful to make a video out of it to better understand how it looks.
I would start with rechecking the symptoms and depending on them for example exchange
the cables.
If all components are from Cisco and you do not get a better answer here and you have
a service contract, you could consider to open a case with Cisco TAC.
