VPC and PVlan support
luqmankondeth
Hello All,
I'm trying to configure pvlans over a vpc but the vpc seems to be down.
I've tried searching for documentation on pvlan & vpc interoperability but couldn't find anything so far.
Could anyone shed some light on this?
My outputs are as below.
P003# show vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 904
vPC+ switch id                    : 904
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
vPC fabricpath status             : peer is reachable through fabricpath
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 1
Peer Gateway                      : Enabled
Peer gateway excluded VLANs       : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
Fabricpath load balancing         : Enabled
Port Channel Limit                : limit to 244
vPC Peer-link status
id   Port   Status Active vlans
1    Po10   up     400-405,410-412,420-423,430-435,440-441,450-451,46
                   0-461,470,480-481,920-921,950-958,999,1040-1048,10
                   51,2400-2405,2410-2412,2420-2422,2430-2435,2440-24
                   41,2450-2451,2460-2461,2470,2480-2481,2950-2959
vPC status
id   Port      Status Consistency Reason           Active vlans  vPC+ Attribute
1040 Po1040    down*  Not         Consistency      -             DF: No, FP
                      Applicable  Check Not                      MAC:
                                  Performed                      904.1.65535
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
-P003# show vpc consistency-parameters vpc 1040
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
STP Port Type               1     Edge Port              Edge Port
STP Port Guard              1     Default                Default
STP MST Simulate PVST       1     Default                Default
Pvlan list                  2     -                      (423,1051)
vPC+ Switch-id              1     904                    904
vPC card type               1     Empty                  Empty
Allowed VLANs               -     423                    423
Local suspended VLANs
P003# show vlan private-vlan
Primary  Secondary  Type             Ports
423      1051       isolated         Po1040, Po1050, Eth4/30, Eth4/31
P003# show run int po1040
!Command: show running-config interface port-channel1040
!Time: Thu Mar  5 10:42:17 2015
version 6.2(2a)
  description TEST PORTS FOR BACKUP PVLAN SERVER-LK
  switchport mode private-vlan promiscuous
  switchport private-vlan mapping 423 1051
     vpc 1040
0 Replies 0
